New to the game
Vizion99
Looking for any and all upgrade ideas, for someone coming into the game. I just bought a MT10 Rival, and I will try to get out and rip it today. I plan on running the 2S batteries, until I get comfortable with the truck and how it handles. For now, I was just looking for any info I should know about the truck, and what I should look out for
The one weakness out of the box (as with most RTR RCs) is the steering servo. To keep the costs down, most RC companies go lean on the electronics. The SC600 ESC and 3300kv motor will treat you fine on 2S, moving up to 3S can really increase temps on both, so check them often (a cheap IR temp gun is worth the minimal cost - Amazon has a bunch to chose from).
Other than electronics most of the truck's components are pretty solid. There are OEM and after-market parts that can improve some things, but out of the box, I think you should run it till it breaks and then decide if you want to upgrade.
That is exactly what I plan on doing. I am buying the temp gun today or tomorrow, and have a better charger and RPM front and rear control arms in my Amazon cart. When I get into something, I go all in. So I'm hoping to make this truck grow with my skill set.
Thanks for the ping, Kevin.
@Vision99: Your quoting 9x19 is good considering upgrading the steering servo. Might I add, perhaps plus up the entire radio system by upgrading the radio/rcvr combo as well.
My stable consists of two Rival MT10's. One stock; one mod. Stock still retains the original XP-120 radio system to keep it box stock original. The MT-10 mod uses an upgrade radio system and changed out the ESC/motor power unit; left the chassis and running gear basically AE MT-10.
Good luck and have fun getting to know your MT-10. Good package overall. -AC
Be careful what charger you buy. Unless you are buying something like the Hota D6 Pro, you'll be left wanting something better. You can grab one for around $120 off www.helidirect.com. just make sure to get the Pro version, which has a built in power supply so you can plug it into your wall outlet.
👆This!
No info on your rig as I’m pretty green too. But one piece of general advice I learned the hard way: it may not be a great idea to be going full bore forward, then try slamming it in reverse. My first couple (admittedly low grade) trucks didn’t have any sort of “protection” when changing from forward to reverse, and I stripped a LOT of cheap metal gears. Definitely helped me learn how to take these things apart. And put em back together without having “ep’s” (“extra pieces” 😂). Good luck and welcome aboard!!!!
Don't feel pressured to jump right into upgrading every component. It is best to just drive the car and see what you break and go from there. You do too much too fast and you can very quickly end up with something that is weaker than stock. The MT10 is extremely durable and depending on your driving style, you may never even have to do anything besides maintenance... or you could break it every time you go out. 😂
As a newcomer to the hobby, you already have a good platform to start with. Spend the money on tools, organization, charger and maintenance items(diff oil, shock oil, grease, tires, etc) early on... That will save you a lot of headache later on down the line. Also remember, just because something breaks, doesn't necessarily mean you need to upgrade that part. Breaking stuff is part of the fun and strategically placed weak points will keep more expensive repairs at bay. There's a balancing act and often times you can created a much more expensive and annoying weak link farther down the line by upgrading the wrong part with the wrong material.
If you have the itch and absolutely need to spend some money on upgrades... wheels and tires are a good place to start. They completely change how a car feels, looks and drives. Probably the #1 most important upgrade for a RTR IMO. Faster steering servo is a good one as well, although id save that for when the stock one goes out personally. If you plan on getting more than one car at some point, a nice radio with multi-model memory is a good idea as well as it can cut down tremendously on the clutter. It is also the connection between you and the car, which makes it a very dramatic upgrade to the experience IMO.
Awesome information! Thank you!
Ifeel like i have so much to learn, and i want to know all of it right now lol. I am one of those people who is all the way in, or all the way out. So, I can only assume that this will become an obsession.
Do you know of a established thread that covers basic maintenance? I don't even know any of that stuff.
This covers quite a bit of the basic stuff. Really the goal is to not let dirt build up on moving components, keep things lubricated, diffs greased, shocks full, etc. You’ll pick up on it and find out your one regiment. Just watch some YouTube videos and check out the stickies on some of the sub forums here.
Most importantly, if you get it wet… you need to dry it off and spray just about any piece of metal with WD-40 or some kind of silicone spray. The electronics are waterproof, but things like bearings are not. They will rust and cause a whole host of issues like excessive heat on your electronics, melted plastic components, binding, etc. Even then, expect bearings to be a common replacement item if you plan on running in the wet a lot. Fast eddy sells bearing kits for just about every vehicle, doesn’t hurt to have a pack in your spare parts bin for a rainy day
