- State of Country Music.
- Racing
I can't afford a MT48 but maaaaan I want one.
Hi,
you can use the MAX8 G2.
There are only some small modifications needful.
You need to cut a small peace from the ESC-Board for the motor.
Second you need to modify the sideguard a bit for the sensorcable.
Attached a picture.
But in my meaning you need no sonsor for a Monstertruck.
That's a smart large cost saving move on Tekno's part to include the hybrid steel/composite hinge pin braces to increase durability. The same goes for the one-piece motor mount. Keeping the kit price attractive is the name of the game. 99% of monster truck owners are not going to worry about pills and a degree of this and a degree that.Thanks. I think I will create one.
I've got the aluminium shock caps + collars in my basket already, and I'll add the aluminium steering rack bushings (TKR5122).
According to the manual, in order to upgrade the A,B,C,D blocks, you need to purchase a lot of additional parts and the cost becomes silly. The stock parts are composite+steel so they should be sturdy.
The Tekno Ti skid plates would be very nice! Unfortunately they don't ship outside of the US. I'm sure in time M2C will make some.
4S Backflips are a no-brainer![]()
A longer "can"/motor will have more magnet area... more torque. Use the pinion guide in the manual as a guide. Gearing is so driving style, and tire choice dependent and will vary from person to person building their truck. Check motor temps as you begin testing/running/breaking in the RC platform. You do have an infrared thermometer, right?The manual lists 4268 2200kv motors as being suitable, but the Hobbywing 4268 G2R is 2500kv.
If you wanted to install one in order to give the wide Max8 G2S ESC more space, how do you figure out which pinion to use?
Are there any major downsides to using the 4268 2500kv over the 4278 2200kv?
A longer "can"/motor will have more magnet area... more torque. Use the pinion guide in the manual as a guide. Driving style, and tires will vary from person to person building their truck. Check motor temps as you begin testing/running/breaking in the RC platform.
I suppose the composite/steel setup could be stronger, I know the “pills” from the OG setup can be broken as well, but I see the assortment of pills that came with the OG MT as a lifetime supply of them, LOL.That's a smart large cost saving move on Tekno's part to include the hybrid steel/composite hinge pin braces to increase durability. The same goes for the one-piece motor mount. Keeping the kit price attractive is the name of the game. 99% of monster truck owners are not going to worry about pills and a degree of this and a degree that.
The difference in pinion size between the two motors is a fraction of one tooth, I wouldn't worry about it. If you're running 14t with a 2200kv motor then with a 2250kv motor you should run a 13.69t pinion. 14t works for me.how do you figure out which pinion to use?
I run a 16t on my MT410 so that's what I'll be running on the MT48.
Thanks very much! Doesn’t sound like there’s too much downside going with the smaller can but it should make it much easier to fit the ESC in.
If I do it, I need to figure out which pinion to get. I’ve ordered a 15T but it might be a bit big for 2500KV.
Castle 1515 2200kv. I'm mounting LP Badlands to it. They're similar in size to 4s Backflips. A bit smaller. I think the gearing chart is for full size 1/8th wheels. The picture on the box shows it with 6s Backflips. If I were mounting 6s Backflips to the Princesses new ride I would probably use a 13-14t pinion.What kv is your motor? 2200?
I just got done doing a driveway test run with it. It corners like a slot car.
It's stiffly sprung, I don't think they would make a difference.So I don’t need sway bars then?![]()
I don't run sway bars on any of my trucks so my opinion probably isn't worth much on this subject.
