STONER RC
Lifetime Supporter!
- Brick, New Jersey
- Racing
- Crawling
- Scale Builder
- Flying
- Boating
As long as the TX was binder to that rx. I would bind it again to be sure... esc goes to channel 2 servo to channel 1 and the fan can go to channel 3...Also when you plug the esc back in it doesn’t overheat or smoke, and outputs the right volts too...
the charger maybe scorched the battery plug, considering the battery is obviously degrading- given the car doesn’t look that old/that used it may be why it’s degrading already?
Or maybe someone plugged the balance plug into the Rx? Would that be a no-no?
@StonerRC365 you’re forgetting my noob-ness mate lol is it worth risking the receiver from my other RC? The axis I wouldn’t dare use as I probably couldn’t find a replacement knowing that old thing haha And will a nitro receiver be the same? I’ll check the Camper and see what’s on that hold on....
So the axis is crystal anyway I forgot that, the camper is a 2.4ghz set up here’s the Rx on that, where should I plug the wires into? And I’ll still need to repair the burned wire before I can plug it in
If I use this Rx will my other Tx work without having to bind etc?
Youn an program with the controller just takes longer with out the card thats all. And a head up the wires for the jst plugs only get crimped not soldered...for future reference bud...they are a two crimp process one over the wire casing and then one over the bare wire.... looks like you soldered them... no need plug it in let play....Well that’s good news mate thanks very much the pdf worked, I’ve ptinted a copy too for my growing collection of manuals lol
Really appreciate the help, I’ll plug it all in tomorrow and see if it works, fingers crossed it won’t fry my Rx lol
May buy that programming card if all is well with this esc too
