- Thread starter
- #21
Maybe I'll pull the driveshaft out to disconnect the front end from the motor and see if it's the same or not. Eliminate that possibility at least
Oh no thats motorAre you sure you have a temp sensor on the battery? That temp seems WAY to high.
Can you screenshot the data?
It's probably that battery is getting severe voltage sag. Does that Traxxas telemetry stuff have a log file?It's still taking a charge just fine. And the voltage between all balance leads is correct. Also, I checked continuity at the ESC leads both to positive and negative- all good.
This was bothering me, so I did some investigating. First off, the Traxxas documentation on their link app is nonexistent. Plenty of links to download it and, if you dig really hard, you stumble upon a blog discussing its features, but zero details on how to actually use it. No descriptors of what each dashboard widget does. So, I downloaded the app on my phone, set up a dashboard, and added the voltage widget so I could figure it out myself.View attachment 259327
what is this? "MAX 213.6"
But just FYI, I had all of that connected before when I was hitting 74mph. Actually today when I ran it I got it up to 57mph again. Maybe the cold weather was affecting the battery, but I'm still not where I was at with 74. We're still talking about 15mph slower. If it was maybe 5 slower I'd accept that, but 15 is too much. That's says there's a problemI have added my LED headlights, tail lights, and "body" lights. The body lights use 1 onboard controller. Each set is plugged into the receiver with a JST plug for power.
Good idea, even one bound up drivetrain bearing could be the culprit.So I'm still without a definite answer to this. I decided to check continuity between leads on the ESC again today as well as the motor leads and everything checked out just fine. I've yet to disconnect the motor from the drivetrain to test the rolling chassis for any unusual resistance or to read voltage between motor leads while manually spinning it with a drill. I guess there could still be something messed up in 1 (or both) differentials and/or wheel bearings. I'm gonna try and do that tomorrow. I want an answer to this!
I am not familiar with this word you speak of: slower.Good idea, even one bound up drivetrain bearing could be the culprit.
May have been asked before, but are the motor and esc warm after these slower passes?
Well, it still charges and still gets up to 12.6volts. And the charger hasn't shown any messages about something wrong. So idk. Drive it til the wheels fall offIf I heard a 'sizzle' sound coming from a lipo, that lipo goes outside in a bucket. Done.
I think that sounds like a typical hobby shop response lol.I disconnected the motor today and tested voltage between leads while spinning it manually. All 3 read the same. Then I went to my local hobby shop to ask them what they think it is. His first question was have I ever changed the wheel bearings. I have not. Then he was certain the problem is that: worn bearings. Thoughts anyone?
