For a charger look at the HOTA D6Pro and I use a combination of XT90s and Deans mainly. If you use genuine Deans Ultra plugs they will hold up fine at least through 6S. The cheap ones will not. For a soldering station Id recommend a Hakko FX888D
That’s a good idea, but I never leave my lipos, (since I have so many I only charge while wrenching and feel them every minute or two)One other option to think about on an new charger is battery Over Temperature Protection or the ability for the charger to stop charging before the battery overheats and bursts with flame.
If you have no idea what this could mean for you, search for "Lipo battery Fire" on Youtube.
If this interestes you look for a battery charger with a battery temp sensor.
You can buy QS8's on Amain for $5.50 each.I would say that anything beyound 4S with a high "C" rating should run these guys, Babuvya High Current Antispark Connector Male and Female QS8-S Black Application with Remote Control Toys Drone Battery Charger Etc (5 Pairs) https://a.co/d/4rFR1kn
Although pricey, they can handle the heat and they are of the Anti-Spark type, as well, so when you go to connect those high current, high voltage batteries together you don't get the shock of your life.
Are the ones he listed not amass so I shouldn’t get them?You can buy QS8's on Amain for $5.50 each.
I don't know who makes the QS8's. I do know on aliexpress you can get them a lot cheaper, but not sure of the quality. Heck, the ones Amain sells may be the exact same ones on Amazon and aliexpress for that matter. You can be the Guinea pig and find out for usAre the ones he listed not amass so I shouldn’t get them?
Will do!I don't know who makes the QS8's. I do know on aliexpress you can get them a lot cheaper, but not sure of the quality. Heck, the ones Amain sells may be the exact same ones on Amazon and aliexpress for that matter. You can be the Guinea pig and find out for us
Same here! I hate those e-flight connectors. The only plus that I have found is they seem to be able to handle more power that the xtsIf your battery packs have inboard/internal bullet connectors, use whatever fancies you. I only had 4mm low profile bullets on hand. Having recently bought some LiPo packs, and didn't realize they came with 5mm inboard connectors (tubes), I did some Dr.Emeling to some 5mm male bullet pieces. I cut out a section (represented by the black area in picture) for the wires to lay at a 90* angle.
The male pieces were left over from EC5 connectors that I threw out. Sorry. Some people love 'em, but I couldn't stand those blue E-flight things.
During the snowstorm in Oregon this year, I had my ec3 connector go up in flames and melt to my ic3 connector. That's why I am looking to get some of them XT90s.I guess no one here, chatting on this thread, ever experienced a motor drawing more amps through it that made the connector melt or get very soft. That a potential fire hazard.
We're spending too much money and time in our RC's to see it go up in smoke. I'm just trying to highlight the points and not teach a class.
The Speedrun Guys can tell you that. The better the connection the better the flow of electricity through the circuit.
Actually, little to no connection is the best.
Some people are more anal about there wiring job then others. Depending on the project that I'm doing at the time, I can be very anal.
QS10 or QS8 connectors plating are better than other connectors just like RJ45 AMP connectors are for CAT 5 - 6 ethernet cables.
How many of you are in the IT field? If any of you are, then you'll realize that a cheap RJ45 connector can rust, oxidize, and short when exposed to high humidity, but an AMP RJ45 connector hold up a lot better in high humidity than others. That's why they're so much more expensive and rated very high up on the list.
QS10 => QS8 connectors are used in boats, scale boats, that is. That's where it is the most popular.
XT90 are my main connectors I use for 4S - 6S projects. I use XT60 connectors for 2S - 3S Mods and Upgrades unless I'm running a larger pinion for a Speedrun. Then I mive up to XT90
You know AMASS do make and sell XT150 connectors that are a lot cheaper than the QS10 => QS8. Basically they are bullet connectors.
Just make sure you use the right size wire, most important, then the right connector or adapter , and a good silver solder job for the load you're putting on your electronics.
https://top5best.com/qs8-connector?...MTos2x4wteSUejTNIHcZ1OaYryCwsx-YaAr7EEALw_wcB
That's a turn in the right direction.During the snowstorm in Oregon this year, I had my ec3 connector go up in flames and melt to my ic3 connector. That's why I am looking to get some of them XT90s.
Generally the cost of an RJ45 is based on different options in the connectors like whether they are shielded or not, whether they use a load bar bar or not, whether they use staggered connectors, whether its a brand name or not etc etc, not how corrosion resistant they are. The industry standard for protection against connector corrosion is to use a silicone dielectric grease or weather proof barrel connectors.How many of you are in the IT field? If any of you are, then you'll realize that a cheap RJ45 connector can rust, oxidize, and short when exposed to high humidity, but an AMP RJ45 connector hold up a lot better in high humidity than others. That's why they're so much more expensive and rated very high up on the list.
