Hello, I have a question I have some CNHL lipos and not sure what connectors are the best (this battery has a 180c burst rate so I think T-plug would melt) and a good soldering iron (budget is $50 ish)
For soldering 8awg? In his other thread he mentions he needs to solder 8awg wire.a good soldering iron is the Miniware TS101 or TS80P series I have long had TS100 and TS80 and they are perfect for our hobby and beyond.
The one I have now there is no way it’s going to do anything to the 8awg it did like 4awg and took forever to heat upFor soldering 8awg? In his other thread he mentions he needs to solder 8awg wire.
4awg is bigger than 8awg. Lower number=bigger wire. You mean it took forever for 10awg?The one I have now there is no way it’s going to do anything to the 8awg it did like 4awg and took forever to heat up
Oh ok, then he’s probably 10awg4awg is bigger than 8awg. Lower number=bigger wire. You mesn it took forever for 10awg?
I need the actual plus there is none on the batterySoldering Irons: My grandpa and my uncle uses this Weller iron.
https://www.amazon.com/Weller-Digit...ocphy=9007913&hvtargid=pla-448477212877&psc=1
They had been using it for probably 25 plus years.
Connectors: I use Traxxas on all of my batteries but in my rustler I have a xt60 to trx adapter and in the slash I have a xt90 to trx adapter. The batteries I use have a 50C and 80C discharge rate. So far those adapters are working out good for my escs and batteries and normal bashing.
But I would recommend to have a more direct connection. I would go for either xt60s or xt90s.
Adapters I use for the slash: https://www.amazon.com/OliRC-Compat...cphy=9007913&hvtargid=pla-1899960407218&psc=1
Adapters I use for the rustler: https://www.amazon.com/OliRC-4pcs-N...ocphy=9007913&hvtargid=pla-955452808959&psc=1
But like I said earlier, I would like to have a more direct connection so I plan to solder on xt60s and xt90s on my batteries. For my SMC stick packs I'll do xt60 or 90 to 5mm bullets.
Are xt90s okay for 6s batteries? I'm trying to figure out if they would be okay because in the future I want to get an arrma kraton 6s and I want to have a good connector besides EC5. For now, I am going to just be running 4s and 3s.Just finished doing the battery connector shuffle. . . again. Hopefully for the last time. . . again. Got lost in adapterville trying to get everything compatible.
XT-90, XT-60, IC5, IC3, Deans ad nauseum. Reset my standard to Deans. Trying the newer HI-Temp (white) connectors. And, yes, the newer whites are back-compatible with the older reds. Hurray! Got a really neat molded IC3/Deans adapter for battery to ESC. All my batteries are 2S or 3S. One 2S and 3S with IC3. The rest Deans now. And Deans are easy to solder and no pesky snap-on shields either. Shrink tubing is just o.k. with me.
Soldering station is a Hakko 936 I've had since '08. It's good for 12AWG; balks at 10AWG. Not enough heat to suit me for making a secure low-resistance connection. Back-up is a 40W Weller pencil for 16-18AWG soldering.
Got an IC5 adapter to solder on a Dean's end for use with the smart charger. IC5 lead came with 10AWG wire. Chucking it in the trash after I take off the unsat cold-soldered Deans I struggled to stick on. Have no intention of transitioning to 10ga. 12-13-14AWG meets all my needs for 2S and 3S. And all are considerably lighter and more flexible than a similar length of 10AWG.
Anyway, have fun Addict. Cheers. 'AC'
I think I’m going XT60 I love how they connect, seem to be the safest one but if I do that all my lipos are getting a XT60, also question, can i solder XT60 connectors onto my traxxas dual charger? like take the traxxas plugs off? I have a single charger I’ll use for the Traxxas lipos if I even use themAre xt90s okay for 6s batteries? I'm trying to figure out if they would be okay because in the future I want to get an arrma kraton 6s and I want to have a good connector besides EC5. For now, I am going to just be running 4s and 3s.
Ok, what’s a good charger preferably dual or triple if they make thatTraxxas only sells proprietary equipment and they have sued anyone who has attempted to make their products compatible with Traxxas connectors. You will need to get a higher quality charger if you want to move away from TRX products:
In the link I provided above, my preference is the iCharger 406 Duo which has recently been superseded with the 456 Duo:Ok, what’s a good charger preferably dual or triple if they make that
Yes, XT90s are fine for 6s. Arrma used them before Horizon bought them (and Horizon uses ECs/ICs).Are xt90s okay for 6s batteries? I'm trying to figure out if they would be okay because in the future I want to get an arrma kraton 6s and I want to have a good connector besides EC5. For now, I am going to just be running 4s and 3s.
Hey Luke,Are xt90s okay for 6s batteries? I'm trying to figure out if they would be okay because in the future I want to get an arrma kraton 6s and I want to have a good connector besides EC5. For now, I am going to just be running 4s and 3s.
I wish I had $300 and if I did charger wouldn’t be taking my money I’m looking maybe $100 ishIn the link I provided above, my preference is the iCharger 406 Duo which has recently been superseded with the 456 Duo:
https://www.amainhobbies.com/junsi-...tery-charger-6s-70a-2200w-jun-456duo/p1470949
DX8 is my second pick:
https://www.amainhobbies.com/junsi-...battery-charger-8s-50a-1600w-jun-dx8/p1411204
