I guess no one here, chatting on this thread, ever experienced a motor drawing more amps through it that made the connector melt or get very soft. That a potential fire hazard.
We're spending too much money and time in our RC's to see it go up in smoke. I'm just trying to highlight the points and not teach a class.
The Speedrun Guys can tell you that. The better the connection the better the flow of electricity through the circuit.
Actually, little to no connection is the best.
Some people are more anal about there wiring job then others. Depending on the project that I'm doing at the time, I can be very anal.
QS10 or QS8 connectors plating are better than other connectors just like RJ45 AMP connectors are for CAT 5 - 6 ethernet cables.
How many of you are in the IT field? If any of you are, then you'll realize that a cheap RJ45 connector can rust, oxidize, and short when exposed to high humidity, but an AMP RJ45 connector hold up a lot better in high humidity than others. That's why they're so much more expensive and rated very high up on the list.
QS10 => QS8 connectors are used in boats, scale boats, that is. That's where it is the most popular.
XT90 are my main connectors I use for 4S - 6S projects. I use XT60 connectors for 2S - 3S Mods and Upgrades unless I'm running a larger pinion for a Speedrun. Then I mive up to XT90
You know AMASS do make and sell XT150 connectors that are a lot cheaper than the QS10 => QS8. Basically they are bullet connectors.
Just make sure you use the right size wire, most important, then the right connector or adapter
, and a good silver solder job for the load you're putting on your electronics.
https://top5best.com/qs8-connector?...MTos2x4wteSUejTNIHcZ1OaYryCwsx-YaAr7EEALw_wcB
