- Thread starter
- #101
New front springs ....try again.
Waiting on the wheel nuts I ordered, and should be able to mount the rear wheels. Should make a big difference. These have got to go....Wow! Looks like a bit of rough day at the track! A few missing parts and a shopping list for improvements... not bad!
Any progress on the wheel hexes for a different wheel set up?
I think the mini b might be trying to grow a beard.![]()
Looks like it lines up much better.A day at the track , even a frustrating 1 is never wasted if you do your part. Yesterday I did a bunch of swearing, added new springs, more swearing.. and more. Today I found the best rear suspension mod for this car as a result.
This is the stock set up on the right rear.
And this is the new set up.
I took the hub/axle carrier and the camber rod and swapped the components from the right to left sides.
Now the camber rod sits in the middle and does rub the cage when the suspension bottoms out. The fit of the lower pivot pin is so tight I stripped the hex head trying to remove it. So I have also reamed out the holes and added thicker, more free pivoting traxxas slash pivot pins. Having done this, everything is so improved I would almost suggest these parts were assembled on the wrong sides from the factory
That and the freedom of movement I would almost run back to track today to test my results. Unfortunately I have work later.....and those rear wheels still need to go.Looks like it lines up much better.![]()
Awesome!!! Nice and smooth!!!
Any kimbrough gear I want!!! Now if I had a motor plate with a swing slot.....Awesome!!! Nice and smooth!!!
That's what I was afraid of when dealing with the unknown. Well, at least the stock wheel nuts, or even some of the other lower profile wheel nuts out there, will give you room to work with.Now that wheels are on the back....View attachment 258162
I need slightly wider hexes to cure a rubbing issue...![]()
Sounds great! Looking forward to pics and mods from another sandmaster. I should be back on this in the next day or 2. I have some wheel hexes to modify to make my rear wheels work. Gotta get over the next town to use a lathe for a minute.Hello
The information you have posted inrelation to the sand master has been very helpful.
I decided to purchase a sand master and I should receive it tomorrow (NZ time).
The sand master has been offered on special at $245.00 NZD from a hobby shop reduced down from $399.00 NZD.
I have some ideas to mod the buggy up so i am hoping we can share some ideas.
Will post an update after my first round of mods.
