AxlPT
She has arrived. Spent the last few nights making some changes.
I knew based on a number of reviews, what i was getting myself into. A number of people in those reviews mentioned the Sandmaster being an entry level vechile that looked cheap. I was sitting on the fence in relation to what Rc car i wanted to add to my collection. The idea was to use spears laying around unused from previous models.
First impressions out of the box:
First mods (front of buggy):
* Removed the stock servo and replaced with a 15kg metal digital servo along with adding an aluminum servo horn.
* Removed the plastic steering links and replaced with metal steering links.
* Removed stock shocks and replaced with some unused HSP aluminum shocks (30wt oil).
* Removed stock wheels and replaced with some disc wheels.
Rear mods:
I haven't changed the spur gear as after the first run, i haven't experienced the noise issues others have had in relation to the spur gear. I did remove the spur gear and she looked ok in relation to the edges or any concerns in relation to the teeth. I installed a Yeah Racing 48p, 23T pinion.
I opened the gear box and applied some more grease.
* Removed the rear stock shocks and replaced with some HSP aluminum shocks (40wt oil) and placed some spring tension on the shock to remove the rear end lag and from bottoming out at the rear.
Power:
Have gone brushless straight off the bat. Using a Hobbywing QUICRUN WP-10BL60 and a 3300kv motor.
Transmitter/Receiver:
Replaced stock transmitter and recevier with a Spektrum SLT3 3CH transmitter and SR315 recevier.
Rear wheels:
Replaced stock wheels.
Appearance:
Not a fan personally of the stock decal appearance of any of my rc cars. . I like a plan clean appearance. Removed all the stock decals and added a few decals running up the front edge of the side panels. Also added some side netting to look like a driver safety net.
I plan to get some black Carbon Fiber decal wrap and wrap all of the panels. I did contemplate painting the panels but wasn't going to spend money on getting paint and primer for a few body panels.
- Bigger size wise then i expected.
- Heavier then i expected in the center of the chassis (i actually thought a battery was inside the battery compartment when i first lifted her out of the box).
Rear mods:
Power:
Rear wheels:
Appearance:
