I did a search on here for related posts...there is 1 mention. I can't be the only 1 who has 1 of these??
I had it out today doing a little walk and bash through the woods. There is also some great pavement in front of where I park so I did a quick speed run. 18mph top speed.
I moved the distance out to 132 for the 1/10 quarter mile since that is what I will be using soon enough.
I have left it mostly stock and plan to. I did change the pinion to a steel 26t from the plastic 27t. I spent some time filing the spur gear everyone complains about, not perfect but it's good enough I won't be buy the $30 delrin upgrade till this wears out. I changed the shock oil in the back to traxxas 50wt. Which has worked pretty well...may go to 60 if I happen to pick some up at some point.
I made a quick video if you wanna skip any commentary and just get right to what the gearbox sounds like 1.25 minutes in is close enough.
