CertifiedMike
RCTalk VIP
RC Showcase: 1
- Southern Maine
- Racing
Pretty much like brand new then! My Dad had one that did the same thing but had more rust.that beater is the best ford ever produced! gave 300 for it 8 years ago 4x4 and everything but the heat, ac, windows, sunroof, back door latch, back window latch, rear defroster, rear wiper, rear doors (child lock stays on wont come off) bad wheel bearings, drains battery if not disconected when done, trailer hitch weld busted so can't use it, hood wont latch down fully ( but it stays closed it just wobbles), radio comes on on its own and wont go off untill vehicle is turned off, door locks dont unlock but they lock, bad shocks, no suspension ( we call it the bobble head suspension, when you hit a bridge you dont stop bouncing untill about 5 miles past the other side), antanae decides to just go up n down on its own, sometimes doesn't want to come out of 4x4 mode, gas hand doesn't work gotta guess based on gallons added vs miles driven, none of the dash works so no idea on speed, using newspaper to keep windows wedged shut,
but other than that it runs great!
its hit a lot of things but mostly on purpose lololol
I've seen SO MUCH worse!!!
4°-6.6°C (20°F)
Its 4° above absolute zero and will remain until June.
It gets up to low 20s for a half hour but its been so cold that everything is frozen. The ground is frozen. Its cold to walk on.
Even tho the temp says 20, the ground is colder.
The temp SLAMS when it gets dark!
