Hi, I need to pick some brains, many years ago I was having great fun when I lost throttle control of the car, Kyosho Inferno DX fitted with a GS21 engine, it decided to attack a stone bus shelter and after hitting it at full tilt, bouncing back about 8ft and deciding to have another go at the bus shelter, it lost and died, culminating in a snapped crank. I ordered a new one but the new one was a modified version with a different thread for the clutch / flywheel, despite searching hi and low, I could not find a correct replacement and the car was put in the loft and forgotten. Fast forward many years and I eventually tracked a correct replacement from Germany. The problem I have is determining if there is a correct dimension for the crank end float, the original schematic shows two shims fitted, part no 6520 - 10., but does not give the thickness of the shim or an end float clearance.. so wondering if any one can advise, thanks
Photos for reference
