- San Jose CA
- Racing
- Crawling
I'm toying with the idea of building a high-speed car and have a few questions.
First is what platform are people using?
Arrma
I'm assuming I will need to play with the pinion and spool to find what works with the rest.
Lastly a long range transmitter, I'm thinking my Flysky might be a bit under powered.
TIA
Arrma
Rebodied Limitless.
Infraction V2 some are rebodied. However, it seems expensive because I would probably throw out the electronics.
Infraction V3 which comes with low end brushed motor, but is less than the Limitless. Might be a good option if I'm chucking the electronics. Are there any chassis difference between the V2 and V3?
Traxxas XO-1It's Traxxas and probably pretty dialed in, but you will need to undo that if you want to go faster. Also may limit big motor options?
HobaoI ran across the HB-VTE2 platform last night. Is it any good, parts may be a bit harder to get than Arrma or Traxxas?
Others?
What is the recipe? - What do electronics and tires do I start with.I see the Castle Mamba Monstor X or XLX2 seem to be popular for the ESC.
The motor(s) is more of a mystery. I see Castle 1717 and 2028, TP Power and Neu Castle motors are popular.
Tires I see foams and some GPMs. Although Innovation RC (Youtube) seems to blow them out a lot. Might be a Florida heat thing?
TIA
