unccpathfinder
RCTalk Qualifier
Hey guys as most of you have seen I'm very green to this hobby and I had some trash Torq engines that did not have the tailstocks on them and I found 1 on ebay for cheap with everything except for the exhaust on it... (questions listed at bottom highlighted in blue to skip my rambling)
The Torq's are a little longer than the traxxas 2.5 (retrofit on the stampede I have) this meaning I have not seen a stock Stampede.
I found the Duratrax Spur gear for the tranny and i feel that I can make it work as the traxxas gear does but i did not drive down to get it since he did not have the exhaust in stock (nearest hobby shop is an hour away)
I mocked everything up and can make everything fit although I will have to make a custom motor mount (no biggie)
1. My question being will the Duratrax spur gear mount cleanly on the Stampede's shaft? If someone has one laying around and wants to take a set of calipers and measure the ID of the center hole that would be awesome.
If its smaller I will drill it out to the size on my traxxas spur gears (easy enough) If its larger I could go to the local ace hardware and create a sleeve to make the spur gear ID match the traxxas gear...
2/3. Has anyone done this? if so how'd it work out.
I will make it work one way or another I have been told several times in my real truck project that it would never work and after making it work I had the same folks who flamed me ask for in depth details on how to do it...so please no flaming on how stupid it would be or it will never work b/c I will do it :thumbup:
