Greetings,
My son's Stampede blew the stock servo. I surfed around and found some recommendations for some cheap Amazon servo's for it. Ended up on a ANNIMOS 20kg. Got it, installed it (with some slight "modifications" of the chassis), and it works, sort of. It wants to rip everything apart when it turns since the angle is so much more than the stock one. I had assumed the receiver was going to limit the throw on the servo, but apparently not. I did notice that I had bought the 270 degree version, which seems a bit excessive. I was in the process of buying the 180 degree version when I thought to check the stock servo's angle. It's 60 degrees. So, the 180 isn't going to help much. The rig only has the the "TQ" receiver, not the "TQi" so I cannot set endpoints. Anyone have a suggestion as to where to go? I would like to avoid buying the stock Traxxas receiver since they break pretty quickly, and aren't cheap. Thanks!
