WickedFog
Community Leader
RC Showcase: 9
- Terre Haute, IN
- Crawling
- Scale Builder
I recommend getting some with cables on them, and I will explain later why. You'll likely need balance extensions at some point, and I would grab these...Ok thanks. I’ll be ordering the charger and LiPo’s soon. Just wanna get all the right stuff. Will these do? View attachment 204560
4Pcs JST-XH Balance Cable 2-6S 3S Lipo Battery Balance Charger Extend Expansion Plug Leads Adapter Conversion Line for RC Vehicles Lipo Battery Charging https://a.co/d/eMoXfkp
And these...
3 pcs EC5 Male to XT60 Female Connector Plug Conversion Adapter with 5cm 12 AWG Wire Cable for RC Hobby Model FPV Drone Car Lipo NiMH Battery ESCL8 https://a.co/d/hxo5hYY
Your charger will last you a good long while, but you can wear out the charge ports and balance ports on it, plugging cables in and out. Extension cables will not only prevent excess damage to your charger ports, but make it easier to plug your leads in.
In fact, if you end up with other battery connectors down the road that you need adaptors for, I would grab a couple XT60 female to XT60 male extensions as well, so you could always leave them plugged in.
And those short stubby ones aren't good to leave plugged into your charger to plug into. They extend out of the charger, and if you are plugging cables into them while they are plugged in, you are damaging your XT60 ports on your charger.
