Who was wrenching today??? What did you do??
Adding a lightbar to the E-Maxx.
Started on an MT10 to SC10 conversion... my Slash 4x4 needs a friend. :happy:
Yea
#bringbackshortcoursetrucks
#makeshortcoursegreatagain
Even tho they aren't the best for the handling and performance side. they are super fun. I think short course truck is a good start if your looking into 8th scale in the future as most 4x4 sct's are based on the 8th scale buggy chassis counterparts.
With only one so far I can't speak for the whole class, but my Slash is a very stable platform. I spend most of my drive time in an area that seems perfect for the SCTs. I still have my Hoss and the back-ordered MT410 2.0, for those times when bigger jumps and silly stunts are on the menu, so I think the SC10 will get more run time than the MT10.
I need to modify the rear light wiring, the MT10 harness has them way too close together to fit the SC10 rear bumper.
I put ElWire in my car. It looks kinda of white in the pic but its actually yellow. :)
Looks good in the car. Did you shove it in a crease or glue it?
Ever soldered some up? I got around 20. I keep yanking the plug off.
Over a year ago I bought a Big Rock slider and parts to kit it out. I've finally gotten around to working on it...
I rebuilt/re-oiled diffs. Added HR 17mm adapters, w/10mm extension, GPM shocks, 25kg servo w/25 t Arrma servo saver.
I'm getting pretty close to being done with the project. The only big ticket item I have is to widen the holes on the motor plate. I plan to use a Team Corally 4S motor and ESC, which I took from my Sketer when I upgraded it to a 6S rig. That Kuron 725 is a 2150 KV motor. It should run nice and cool with a smaller rig on 3S. I might even try going up to 18 teeth on the pinion with that kind of torque on 3S.
I'll post updates once I finish the project, hopefully next week, and get this little beast up and running :)
Got a CRC pinion set today and put them all on the pinion caddy. 48T - 69T. CRC also makes pinions 20T - 47T but I got the larger set to take out the ridiculous acceleration in my pan cars and make them more comfortable to drive.
I need to get a set like that, but for offroad.
The gearing I run in my cars is what it is because thats all I have mostly.
Sweet, nice setup. 🏁
