SICK!!!!
Dude, that looks freaking awesome!
SICK!!!!
Thanks bro. Going to get some decals on it in a bit.SICK!!!!
Dude, these new pics really shows off the window trims, and with those decals, this body is just getting sicker!
Dot 3 brake fluid.I pulled the nose piece off of the baja and tried to strip the factory finish. I was able to strip it with paint remover but unfortunately it also ate into the plastic, so that was a huge fail.
I think I'm going to build a vacuum form and mold it myself.
I used to have a cat like that. He had a purr like a Huey helicopter He was a total lap cat. But he had to dig his claws in whenever you pet him and he got that purr going good.Got the red shot on my wrangler body, and plasti dipped my dodge body accents. Mr pickles demamded my lap, so no photos at the moment. Hes a complete purr factory.
Dot 3 brake fluid.
Nitro fuel works, but makes the plastic brittle amd thin after a while.
Wrong hole!Holy moly, I did some wrenching today.....it's an after Christmas miracle!
So today I worked on the green SCX24 Deadbolt. I thought I'd give the old inverted shock trick a try after hearing my arch nemesis @Xraycer did it.
I took the front springs out and inverted the front shocks, then inverted the rear shocks. Mounted to the frame rail as per SCX24 wizard @Pat_ranch suggests.
While I was in there I trimmed down my battery tray, Cut it almost in half right behind the velcro strip. This is temporary until I can make some longer wire leads, so I can move the battery and receiver positions.
This is how much I removed.
Then end results of the shock mod are quite a bit more obvious than I expected. Here is the freshly modified green Deadbolt, next to Ogre unmodified shocks. Quite a bit of lift.
I ran it over a few obstacles on the kitchen table and i'd say overall it was a successful modification.
CURSES!!!!So today I worked on the green SCX24 Deadbolt. I thought I'd give the old inverted shock trick a try after hearing my arch nemesis @Xraycer did it.
Wrong hole!
You'll get better useful travel and performance if you put it in this hole....
That's what she said!You'll get better useful travel and performance if you put it in this hole....
