- Great Smoky Mountains
- Crawling
- Scale Builder
- Flying
I'm hoping the "Like" of my previous post means my wiring is correct. I should be getting my servo today, and hopefully I'll be able to get it wired up and put back together tonight. Where have you Wraith owners stuffed your BECs? I'm planning on putting mine behind the dash, at least for now, I may get Da Box and Da Tray pretty soon. I need to get everything ordered before I get home, then the wife may not notice.....as much.
It is justified, but the Field Link card doesn't work with the Quick Connect unless you use a PC.I'd also be interested in knowing if that "Like" is justified, part if the reason I went tekin was cause I didn't/don't have a computer to readily ajust things with a castle link, also the reason I keep putting off getting a holmeshobbies ESC/motor combo. Tekin RX8s are mostly programmable without needing a "hotwire".
I've got the BEC plugged into the battery ch on my rx, I get power to my rx, servo, and lights as soon as I plug my battery in. The lights will be a good reminder that I didn't disconnect my battery, plus I can use it as a flashlight now without my ESC beeping to remind me that it's on.If you've pulled the +wire from that " quick link" then I presume you plan on sending power to your RX some other way?
That's just trying to go, I have to ease onto the throttle or else it just stutters. It looks like a dog humping a leg if I try crawling up something. I figured I wouldn't be able to crawl anymore, but I was hoping to be able to play around in the sand a little.That sucks, hate to hear that buddy. The only way brushless systems work well for crawling in to use a sensored setup, even then it's not quite as good as brushed. It's close enough for me, but my brushed rigs still have better low speed resolution on the throttle. Now if you're just bashing around, that's a whole different thing. Throw a cheap brushed motor in it, lots of guys run the Traxxas titan motors.
It's stock gearing right now, I don't remember what that is though. I was thinking it would be too slow with the 2900kv motor, I almost ordered larger pinions. I had updated the firmware before running it, I'll look into tuning it more with the Castle Link. I may just have to wait until I get home and can throw a 3s pack in there.What's your gearing at currently? It shouldn't cog that bad I wouldn't think. After some research, it appears that some of the vanguard stuff is just rebadged Castle electronics. Check the firmware on your ESC, and see if there's an update for it. You can also play around with the punch control, and start power to try and minimize the cogging.
We'll need a video.It looks like a dog humping a leg if I try crawling up something.
20/80 right now, it's the stock setup. I'm looking into throwing some 32p gears in it, that should open up some more gearing options.What's your gearing at currently?
I'll see what I can do.We'll need a video.
