FourByLawl
- Thread starter
- #21
So I went ahead and changed over the diffs as the diff housings never came with them. The rear sits fine, the front doesn't grind but you can feel it turn over.
I suspect the mesh hasn't worn in properly, I re-toothed it, just changing the spur a little and it's smoother.
I have seen someone post a vid where it was hard getting the ends off the rear when he was switching over to portals, I don't have that issue and am not going to tighten anything where it would cause an issue, when the other gear drops, I should be ready to go.
Not much else I can do here, and I can't order more diffs as they will take another 2 weeks to land.
It all appears to be slowly coming together.
EDIT, I might be getting the limited slip diffs, maybe just for the front so I have better turning and keep the rears locked for the 6wd if it happens.
