zepplin
I deceided to attempt the Savage S25 engine mod featured in Jan 2005 RCCarAction magazine.
I have read the article over several times. I have deceided to dissasemble my fairly new S25 engine in order to get a better understanding of what is required.
I was able to remove the flywheel by removing the carborator and jamming the handle of a plastic tooth brush in the drive shaft fuel opening in order to stop it from turning when I untightend the flywheel nut. I also used the plastic toothbrush handle to pry on the backplate which was rather tight.
I am now trying to figure out how to remove the piston sleeve. It pushes up a bit when the piston reaches top dead center but no more. I tryed warming the engine with a hair dryer in hopes that heat would expand the metal. no luck. I am still looking for something that I can use to pull the sleeve out of the block that will not damage the sleeve.
Any ideas how I can get the sleeve out?
