I started brushless with the revo. Prior to that, I ran nitro only for 18 years.
My wife got it for me for Christmas in 2016.
I put different tires on it that were some I had on hand that stayed nice and soft in the cold so I could run it in the snow.
I stuck with stock arms/carriers, just to try once again with stock parts... my 2 nitro revo's would suggest this was a dumb move... 3 days after getting it.
And 7 days:
One month in and changed to RPM true track in the rear, RPM arms/carriers in the front:
After reading the issues with running 6S in it, I only ran 4S in it it's entire life. I ran SMC 2S 9000mah packs, which barely fit in it and were super heavy:
I later changed to SMC 2S 7200mah hard case which were lighter and easier on it.
I did upgrade a bit on it, like this rear motor brace:
Which I put a turnbuckle on to the rear body mount for extra stiffening in the rear.
Tried some SRC tires/wheels on it for a while, they did ok, but I did spin a hex in one and they didn't do well with big jumps. The lack of sidewall made them like rocks to land on:
Added alloy rockers after busting the stock plastic ones a couple times:
Changed to some different tires to give me a bit more cushion for landings:
Bashing around in the dirt pretty much nonstop would get me more than 30 minutes of run time on average... those were the days...
Geared for 45mph:
2017 Christmas got me a roll cage to help keep the bodies from disintegrating in 2 bash sessions, and a new set of wheels/tires from my wife:
The larger tires caused some suspension issues though, kept ripping the rod ends off the rear shocks and pushrods, so I made some limiters tied to the arm and rear body mount to help fix the issue:
The roll cage was annoying to work around and it kept snapping my front body mount/tower thing into pieces... so I made a roll bar to support the center of the body. Really wish traxxas made this like they did for the nitro version. My version looks dumb, but worked well:
And 7 days:
Geared for 45mph:
