Timmyboy
Hi everyone,
New to the hobby, so I know practically zilch other than what I've managed to read on various sites.
I bought an TT EB-4 a couple of weeks back out of the local paper, just because it was dirt cheap Had good fun with it and no problems with getting the engine running etc (pull start), right up until the time my father in law drove it into a curb.
Anyway, got some new suspension arms on order and bought a Savage 25 from the local paper for the same cheap reason - I've always wanted monster truck RC, it seems a bit more robust than the EB-4, it looks cool and is more suitable for the kind of areas I'll be using it in.
Anyway, I'm having a bit of trouble with it.
No problem getting the engine started using the rotostart. Original owner used 25% fuel so I've got some 25% ODonnel in it.
I've only tested it in my fairly small garden so far, and it is quite happy pottering around in circles and will continue to do so for as along as I like.
If I give it full throttle however (which I can only do for a couple of seconds due to space) it shoots forward ok, but as soon as I let the throttle go, it stalls.
I'm guessing the first sensible thing to do is to take everything back to stock settings and tune it from scratch, but is this a common problem anyone recognizes? Not sure how long it's been sitting around so perhaps it just needs a bit of running in?
Also, couple of easy ones:
1) Should I be using after run oil?
2) Got 4 rechargeable AA's in at the moment, so only 4.8V. Do I need 6v? If so, will the 6v savage hump packs I see on eBay fit? Only ask as I've got a 6v hump pack for the EB-4 made from AA batteries and it would never fit in the Savage.
3) I see the throttle has a return spring. I fitted an electric failsafe in the EB-4, is it wise to stick one in the savage in addition to the spring?
4) Is the reverse gear worth having, if so, is it a nightmare to fit?
Thanks in advance for any help, sorry to bombard on my first post
