2revo1maxx
This has been a long row to hoe, but I am closing in on it.
So far, I took a junked out 2.5 with a Picco 26 Max and installed:
A 3.3 Chassis, Brace and Half Shafts
GTR Ti Shocks
Traxxas CVDs
RPM True Track Rear set
RPM Front A arms and pivot caps
Aluminum Front Toe Links
Aluminum Front and Rear Push Rods
Center Differential
Rear Brake Kit
Water Proof Digital Throttle Servo
Waterproof Digital Steering servo, single
Motor Saver High Flow Air Filter
Hardened Clutch Bell
Hardened Spur Gear
Replaced any missing fasteners
Added a Traxxas Wing
Still waiting on new shock mounts, the truck had Integy mounts on it, they do not allow the roll bar kit to be installed. Also waiting on a THS Pipe.
I have begun to setup the truck for ride height. I am happy with the front end... green springs with pro 2 rockers. I may move down to stock springs, but this is a basher. I have silver springs in back. The rear ride height is where I want it, but it still bottoms out to fast for my liking. I do not want a heavier spring as it would change the ride height. Does anyone know the stock weight oil in GTR Ti Revo rear shocks? Is it 40 weight? If so, I'm am thinking on moving to 50 or 55 weight if I can find it.
I did paint my first body this weekend. It is a Proform Hard Drive. I found putting a mask on the hood with all the vent like stuff to be very difficult, even with a hairdryer to warm up the vinyl. Anyway it is painted, and since it is my fist body, I am not embarrassed in the slightest.
Been fun so far!
Yeah fun is where it's at. I believe the stock oil would be 30 wt. I use 40 wt it works quite well. Look up 'revo setup sheets' on google you can find the setup sheets that Steve Slayden (Traxxas driver) and many others have used on their revos over the years. It's a good tool if you don't have the manual because (for example) you have to set up the bump steer according to your caster and so on.
