You and me both! I love my two RS4 3 cars. Beautiful job on the resto of all of these @gandalfnzStill jealous of the score.
Here's one on amazonDoes anyone know if the small temp monitoring devices can still be found somewhere?
ThanksHere's one on amazon
It might be a little large to use as a permanent feature, but for tuning it should be fine. Could probably pull the circuit board out of the housing and make it smaller that way.
You sure this is a restore and not an unboxing?
Great content as always. I kinda like all the blue on that one.
I noticed that on HSP engines, there is a gap between exhaust header and exhaust, even when you use original gasket.
Oh god, yeah. I completely forgot about that issue. It's insane to me that such a prominent flaw made it to mass production.
I dig the purple cooling head, I'm kind of itching to do an all-purple build.
The stock gasket has a flange to try and make up for the difference, but it still leaks.
I think can tell how it happens, they machine the face on the header down too much, opening up the passage too wide... probably because it's a clone of HPI's squarish manifold. The aftermarket manifolds don't have this problem.
I've been meaning to get some speed posted, but it's tricky to film / hit max speed at the same time. Tumbled mine last time and took some damage, but the engine kept running even with the mounts knocked out of alignment. You can also peep the aluminum diff cases I upgraded to:
I don't know how you get these to where you can't tell it's not new. Amazing work.![]()
I have tried the same header as yours, but it still leaked, that one has a much smaller opening, I wonder if it affects peformance?
Whats that fancy analyzer RX box?
Hey, those mods look very useful, I was thinking of just buying a cheapie skyrc gps module to measure speed.Didn't seem that much smaller to me, if anything it ran/sounded better.
A SkyRC GSM020 held on with 3M double-lock. It has both "Track" and "Drag" modes to measure top speed, distance traveled, G's of acceleration, all via bluetooth app. It's tiny bit buggy sometimes but has always worked for me after a quick reset of the unit or app, and it nestles very nicely into several places on the car.
Good time to mention another mod I've done - I cut my radio tray into front and rear sections so I can remove them separately, which makes working on the transmission a lot easier because of that one tab that entangles them and makes you remove them together.... Anyway, on the C-link version they're 2 parts by default, but the pivot ball version stretched the radio tray from an L-shape into a rectangle and fused them into a single piece. Here's my split, using the original front tray which has more "meat" for the doublelock to stick to.
You could mount yours on the back of the radio tray, like this:
I wonder if my two speed works, really itchy to find this out soon, but break in will take a bit of time.
I know on my friends HSP, both of his are not kicking into second speed.
You have been such great help in this last restoration!Mine works, but again, quirks abound. Here's a rough, bodyless video where you can hear it engaging clearly.
That break-in sounds healthy. Going back through my old videos, I realize that it is sounding a lot smoother even now than it did even after I thought I was "done" breaking it in, yours will be singing after a gallon.
The second speed gear has a pin pressed into it to catch the "claw" of the clutch; without this pin the plastic is quickly worn away after a few shifts. Replacement gears and even assembled transmissions are sold without this pin in place, I've had to press it in myself. It appears to be 2mm x 8mm, which means you can grind 2mm off one of the axle-hex pins to make one from scratch.
I've even had it work itself out, so I hammered one end flat to retain it... After that, it worked, but I can see where other people's troubles may start. They sell a metal version of the gear but it's steel and heavy af, I wouldn't want to imagine that at 15k RPM...
