Hello everyone
I'm new to the site, but not to R/C. I just bought a Kyosho Fazer 1970 Dodge Charger brushless setup. I normally do off road bashing, but wanted an on-road car to do some parking lot cruising.
I got a different set of wheels & tires, put them on, and straight away had issues. On one run, one of the screws that secure the wheel to the hub just...un screwed. Put everything back together, and tightened down the screws, but that lead to the drivetrain not moving. So I got the screws just snug and carried on.
So I was having a good old time, until another wheel just flew off. I was prepared for it to be another screw that came loose, but this time the plastic on the wheel had melted at the point of contact with the screw! I checked the other screws, and they were all hot. Normally I would blame a bad bearing, but the way the setup is, the bearing is around the outside of the dogbone actuated hub, and nowhere near the screw.
The screw goes through the hub, and if tightened too much, can make physical contact with the dogbone? Could that be the cause of the overheating. Any other Fazer driver encounter this problem?
