HueyC
Hello friends,
I'.ve recently ran into an issue with my nitro RC and can't make out what is causing it. Initially, I thought it was tuning issue, running too lean but spitting oil out and plenty of smoke. I've attach a video in hope that some can point me in the right direction... almost sound like it "flat-line" from time to time... or burp like something was engaged and then free-wheeling... I know throwing out these two examples trying to describe the sound but hopefully the video will help. If you listen, you'll hear it come in and out... maybe air leak but I've ruled out the fuel tank; already did submerge test under water and fine.
One thing I have discovered is that the flywheel will turn CW for 1/4" and then lockup. On my other Nitro vehicles that are not "Star T3.0" engine, I recall that it will not turn CW, only CCW. Not sure if this is an issue but this is my second engine replacement. I've checked the original T3.0 and it does the same thing... able to turn the shaft CW for at least 1/4 - 1/2" turn
