Getting started in the hobby! First planes, first impressions
That is an odd looking cooling head on that ASP, but then again there is so many variants out there, you never know.
I see, your are prob right, I thought I saw a Chinese 10cc rc plane engine, most likely it was 15cc then.
Was at the club yesterday and a guy with a AX was having issues tuning it, actually his first AX piston tore the liner for some reason, and this brand new one he installed wasn't running right. In the end he said he has a LA 46 which he will put on it. Found that funny. LA again takes the win.
Also, have you tried flying or see someone fly a control line plane at your club?
Another guy I spoke to, purchased a $4 foam plane from a store, added a bell crank and elevator made to work.
Thin plywood firewall and strapped a cox 049 on it. It flew great.
I want to try this, as I have a few 049 cox engines, just need to buy one of those glow plug converters so it can take a standard glow plug.
Managed to land perfect a few times yesterday, was told I can soon take the test and fly solo. :)
You're right about 10cc 2-stroke gassers (and even 6 and 9's,) I just meant within 4-strokes that were also gassers.
My club has a control line area, I haven't given it a spin yet... 😉
A simple, wire -shaft driven control line plane was one of my first forays into flight when I was a wee lad, so it would be fun to revisit that for sure.
I see mention of those peeling liners now and then, fingers crossed it doesn't affect mine. I hope that with my surface engine experience I'll have a head start on tuning and engine care. I'll be running a 15% nitro, 2% castor, 16% synthetic blend that should be good for just about any engine.
Congrats on the flying successes!
This is where I am still kinda lost. Oil content.
I purchased a gallon of aero fuel (I think omega fuel) which had 18 oil total, synthetic + castor mix.
Having visited RC forums a number of times, I was told that older engines like to have min 20% castor, so I added another 2% of pure castor to the gallon.
To be hones, be that as it may, all my engines spit a lot of oil out the exhaust, making quite a mess. At least, I know that engine will definitely last a very long time.
I have about 8 gallons Byrons 20% nitro 16% oil RC car fuel, to which also I will just add another 4% castor and use it on my planes.
If I could give one tip, that would be to always mount your engines sideways on a plane, that way exhaust oil spitting is minimal and ends up going underneath the fuselage, rather than having the whole wing and more all oily.
little bugger has been cleaned, with just a toothbrush and simple green
I noticed that ultrasonic cleaner was taking away the chrome finish on some engines, not matter which solution I use?
Anyway, I hope you acquire one of these small 4 stroke for a decent price.
Def worth having in your collection.
I tend to run these engines on a test bench first, then look for leaks, and seal as many as I can. New O-rings and high temp silicone usually do the trick.
I hear 4-strokes might be better off with no castor, and the tiniest engines prefer even more, like 20% castor in a Cox .049' - Id like to fly one of those just for the retro factor. What do you run in your 4's?
Nice ASP, I picked up a few of my own- an FS-62V and a Saito FA-40A. Definitely keeping them in the box until my third or fourth build. My engine collection is already spiraling out of control like it did with the surface engines, though I've been able to re-sell a half dozen of those already more or less at-cost.
Got my first solo flying day in, I started with the parkflyers to build up confidence, then launched the 1-meter trainer.
It flew nicely, landed intact on my first attempt, and got a half-dozen more flights in before a gust flipped it on its nose during a touch-and-go, but it'll be an easy fix, especially compared to what it takes to keep a nitro car running...
That 3D-looking foamie, the Qidi-550, had constant connectivity issues and wound up in a bush. It was dropping connection even during the bench set-up, but for $60 all-inclusive, I can't complain. It's 1 new radio away from being a very nimble 3D plane.
The cheap Aliexpress planes impressed me, for under $50 RTF, I'm hooked. I've already ordered their mini-EDF and flybarless heli.
Blame the wind, a classic! I think you will make a fine pilot :)
Me and the little one flew yesterday, 3 batts each. He is only doing ailerons only at this stage.
I fly on my own now, no interventions from the instructor were needed, did a few loops, rolls …. even tried landing and taking off downwind just to get the feel for the difference. Good fun!
I still find landing challenging even with small winds, the plane yesterday just hovered in place a few times, the wind was just pushing it back.
Its all in the throttle control, with tweaks needed frequently as you land.
Park flyers are ok, but just keep in mind that smaller and lighter planes are even more difficult to control.
I believe that once I move onto bulkier balsa models, I will find flying easier.
Will be doing my wings in the next few weeks.
Wow, those engines looks awesome man, looks to me someone can't resist buying. Top quality stuff! I have some catching up to do :)
That small Saito especially looks nice!
Sorry to see you crashed the trainer, for foam I found that cheap gorilla expanding glue works real well, or you can just use some thick CA, although be careful, as some CA will actually melt the foam.
I haven't fired up any of my 4s yet, but will be using the same fuel I use for my smaller OS engines.
I got only one more 4s, its a ASP 91 on the Aichi D3A, a Jap dive bomber. Original owner stripped the glow plug hole thread, which is a nightmare to repair, being imperial and a special size. I have removed the head and given it to an older engineer at the club to have it fixed.
Reason I try to stay away from cheap Chinese radio gear (lesson learnt from nitro cars), is fear from losing signal mid flight.
Keep buying them mate, and please keep me updated with photos and even videos!
Just purchased another cox 049 today, have 3 in total. Same as you, I would like to make one very small nitro plane, just for the fun of it, later on.
Heres my Jap dive bomber awaiting the glow engine head repair
That cowled 4-stroke looks awesome! Can't wait to get mine running.
Fixed mine up, got another good day of flying in. Waiting on a generic GoPro & headband to start recording some flights. It's performing admirably as a first beater. It'll do loops & aileron rolls, and handles dead-sticks very gracefully. No crashes this time, though the motor did feel & sound a little rough from last time, but that just added a realistic buzzing noise to the flights.
Radiolink hasn't dropped signal on me once yet, I'm pretty happy with its performance thus far.
I am waiting on the ASP91 engine head to come back with its glow plug threads repaired, so I can fire it up.
You seem to be doing well with your learning how to fly, and by the sound of it are already flying solo?
These first plane of ours are are write off tbh, if it teaches me and the boys flying I will be amazed. We were very close to hitting the ground last week.
Was kind of hoping it does crash so I can get turbo timber, saw one locally for now too much.
I realized I have few AS3X SAFE receivers, and am thinking of getting a small plane and flying by myself in the local park. SAFE should help with this, however its a bit of puzzle on how to set it up on my DX8e.
I am thinking about purchasing the micro mini stick from Real Hawk on Ali, and setting it up with a cox 049 nitro engine.
Was thinking maybe we could both start on these at some stage and share ideas.
I will get the whole plane with the covering and all.
Will post a pic soon of my engine collection, its all 2 stroke though.
I have fired up my little ASP FSR30. It runs well, still I think you can beat the simplicity and reliability of a 2 stroke.
That thing is singing, I would never guess it was only a .30 from that throaty rumble!
I've got my mini-stick kit in hand, it'll be my first balsa build to sharpen my skills. I'm not sure if the included films are nitro-fuel resistant, it'll take some experimentation. Definitely going to be posting about it!
I'm also interested in the between-.049 and .10 engines, like the Thunder Tiger GP-7, Norvel .074, and SH-7 engines, and they've got a few models about the right size for those, too.
I've gotten a couple solo flying days in, most recent one with no crashes! I bring that inverter-brick that I was using to preheat my onroad nitros and field-charge my batteries as quickly as I use them up.
I'm amassing a mini-flyer collection, I've found I can enjoy a toy-grade flyer a lot more than I would a toy-grade truck. That mini Aliexpress plane, "F949" I was posting about earlier has a gyro you can toggle on and off which is just as effective as SAFE, except the whole thing costs under $45. It's throttle, rudder & elevator only, so it's got kind of a weird, "driving a car around" vibe and it can't do rolls, but it will do loops (with the gyro off).
It spins that 10x6 quite happily at nearly 10k rpm.
The micro mini stick, I haven't ordered yet, been spending $ on tools and probably some stuff I will never end up using, but still nice to have none the less.
Please let me know which glue are you going to be using when putting the micro stick together?
The small engines, I decided to go with cox, as I think its the most widespread, there are plenty of spare parts out there...etc, and I believe they are still being produced? Are there other brands out there, more common than cox?
Good idea about charging the batteries on the go, just be careful with charge current, usually the faster you charge them, the shorter the life of the battery. We have a quad battery charger on site at the club, solar charge, so that's quite handy.
I also had my solo flight the other day, no buddy box, it was all up to me... windy condition landing I find challenging.
What do you mean by a toy grade flyer?
Few more very interesting things I purchased, tools...tools...tools, love the tools!
That's a nice collection, is that a foam cutter or a jigsaw of sorts? I've got some mini-tools I think will lend themselves well to the plane crafting, namely the tiny drill press and table saw.
I don't know of anyone else still in business doing .049 engines, it's pretty amazing that Cox is still producing them, or at least has enough stock to keep sales going.
Edit: Norvel currently offers a .049 engine and a few others in that size range.
I know SH Engines has a .07 aero engine in current production that only weighs 100g, nearly identical to their 1/16th surface engine, just with a smaller cooling head and closed backplate, the rest of the part #'s are the same.
I'm going to try putting the balsas together with plain wood glue, Titebond Original, might thin it with a little water if I need. I have some 30-minute epoxy to reinforce critical areas / coat the engine bay like I hear one should, though I've also go some urethane sealant I read may be just as effective and lighter.
By toy-grade I just mean sub-$100 RTF's that include a cheap radio/remote and unbranded battery. I got the FX9630 EDF, ~$50, and carved out the battery bay to take a 500mah 2S, based on the reviews suggesting more weight in the nose anyway. It's pretty clever, it only has the 2 "elevon" control surfaces, but uses mixing and differential thrust to create "full" 4-channel control.
I also got a cheap gopro knockoff (EK7000), and I have a narrower field-of-vision lens on the way to make it better for RC recording...
Started the balsa build, glad i'm practicing. The instructions suggest super glue to tack things into place and white glue to reinforce it, but I'm getting good results just applying a thin bead of wood glue with a toothpick and holding the parts together for a minute or so. That already creates a joint stronger than the surrounding wood anyway, so I don't see much point to clamping or reinforcing it with extra glue afterwards, maybe just laminating key areas to reinforce the wood itself.
I wound up with a little bit of twist in the fuselage, good lesson going forward to check for that in addition to just the squareness of individual joints.
One lesson already learned, look ahead and plan your cuts. They say to cut 2x 70mm pieces of balsa, but don't specify that you should cut them from different pieces so the remaining lengths will work for the other cuts you need. I made it work by splicing the length where it passes through a bulkhead, but it would've been easier to plan all my cuts before starting.
I'm not sure if this will be large enough for a Cox .049, maybe a .020? Someone even fitted one to one of cheap planes I tried and was duly impressed with-
After watching a few videos on scratch builds, you will need a thin and thick CA glue. When to use them is another story, I haven't figured it out yet.
I think for soft balsa joints, once in place, a small squirt of thin glue gets the bonded together as balsa easily absorbs it?
I would use epoxy for the firewall only.
For the rest I was thinking of getting this glue.
I'd like to avoid having to hold parts together for so long.
I thought this kit is fully laser cut?
Pretty sure them flying on YouTube with a cox 049, it will have to do, as the price of 020 engines is quite high.
I saw a toy grade $4 foam plane a few weeks back running a cox 049. Used for control line though.
Ah mate, way ahead of me as usual, you are already flying jets!!
That's a scroll saw, apparently one of the best tools to have for butting thin ply and balsa. Tried it, works well.
I had a look at that SH 07, looks weird, like you said its shrunk car engine, no hard connection for the exhaust too, just a silicone sleeve.
Use two part finishing Zpoxy resin for fuel proofing the firewall and the tank bay area. Zpoxy is great, and comes in two big bottles, so it will last you a lifetime.
Love your mods and experiments, also trying to always find the most cost effective solution.
Please keep me updated on the micro stick especially.
Is the plan to run off the cox attached to the engine fuel tank, or install a separate one in the nose/fuselage?
I'd like a separate tank in mine, probably 1oz or something, as it needs to be quite small.
I think I saw the same YouTube video, that thing was ripping.
Looks like they were talking about this on the Cox forums, 10 years ago.
Edits: I found the original hobbyking listing- The laser-cut parts are a bit different but the design seems the same. In an incredible stroke of helpfulness, they have pictures comparing a .020 and .049 to the frame - I see the .049 working better with an internal fuel tank like you suggest.
The kit is fully laser-cut, you just need to cut 2 balsa sticks to length to reinforce the fuselage, nothing too precise. However, forming the leading edge involves glueing a square piece balsa along the front of the wing, and then sanding it down to shape. Probably common practice.
I'm not sure this one will ever be finished to a flying state, it's already got a few goofs built-in, mostly just for the practice so i dont butcher my first "real" build. I'm still going to cover it with the iron, and I imagine that'll be educational too.
If I'm going to build a nitro 1/2A I'll probably make another plane for it, something prettier than a stick, this recently caught my eye. I like the idea of a separate tank, but there is a certain charm to the "standalone" engine just bolted to the front of the plane.
If I were to go with the integrated tank, I'd forego a throttle entirely, maximizing simplicity & retro-ness.
I did find one more manufacturer offering 1/2A engines, Brodak, has both some modernized cox engines and an in-house .049
I corrected the twist in the fuselage by dampening the whole thing with a spray bottle and clamping it flat overnight, by the morning it held straight.
Shaping the leading edge was very satisfying too, using a Dremel to do the initial roughing down and then finishing it with the included file.
I think I'll make this one electric, found a little 7A ESC and motor that should fit nicely.
Electric pfffftttt.... you'll be back to nitro in no time.
Agreed, its probably a bit much handling a new plane, learning to fly and dealing with nitro engine mishaps.... can't wait to see your nitro iteration.
Very good idea about dampening the wood and leaving overnight.
With a another little one on the way, I think the hobby might take a bit of a back seat, but I still have a few weeks more to buy more planes.... :)
Picked up a coupler over the weekend, A world models stunt 40 and Beagle b121 (in the photo). Gave the World Models to a mate, and kept the Beable, I just like the look of it.
Came with the ASP 52, engine is new, I think its only seen a break in run. Compression so good, can barely turn it by hand.
Garage running out of space...
View attachment 182546View attachment 182547
Having an integrated tank will make keep the plane in the air for a lot longer, I think.
Those cox attached to the engine fuel tanks are so small. A min or so in the air, and then dead stick landing shortly after.
Congrats on the little one, that's great to hear! I'm sure you'll have them flying in no time. That's a happy looking garage, definitely making good use of the space! I didn't know you had nitro helis too, those look like some monsters.
Thanks. Sorry for late reply, its been a hectic few weeks.
That's an (white/blue one) Align Trex 700 Nitro Helicopter, which I don't dare fire up on my own yet. Since the Aero club we joined is huge, there's a helicopter section as well, I had a chat with the boys over at the Heli area, they told me to bring it in for them to inspect and see whether its air worthy as is.
Red one is some Chinese off brand, which I am selling.
Not interested in flying them yet, but I scored it for a good price, and you never know when the itch will kick in to try something a bit different.
I have been busy buying engines and more planes.
What's cooking on your end?
I think you asked me this before, so I will return the question, which fuel are you going to use in your 4 strokes and 2 strokes?
Purchased this bad boy at a garage sale a few days back. Will make a neat project. Not sure, if I want to use it, since its about 60+ years old, would have to see it kiss the ground and break.
I got two of the same, one crashed (with a good cox engine and other bits and pieces) and one in solid condition as per photo.
Its a Cox PT19 CL Flyer. A very old kit.
Those CL planes look like some real classics!
I tried helis in Phoenix Sim and I don't know that's for me... A bit too squirrely and I have a hard enough time keeping my bearings with a plane, much less something that can yaw 180° in a fraction of a second.
I was going to add to my last post, you know my weakness for engines all too well - I wound up scoring a .020 for $60, in great shape, so now that balsa stick has a future with fuel:
I'm thinking I'll run my 2-strokes on Torco's 15% airplane mix, which has 16% synthetic & 2% castor oil.
I've read contradicting opinions on "4-stroke blend" fuels and whether or not castor is better or worse for them, so I'll probably run the Torco in them too. I was impressed with their Car/Truck 30% and the price is favorable.
For the Cox engine, I'll probably buy small bottles of pure nitro, methanol, and benol klotz, and make 25% nitro / 20% castor, can't seem to find that particular mix retail. Won't be as much of an issue since it'll use so little for each flight.
I've started building my "big plane", an Avistar Elite. I found a carbon fiber tube with the right dimensions to replace the stock aluminum one, saves 50g of weight. I'm also reworking the servo mounts to use 15x35mm servos since they'll be plenty powerful for a .40 size trainer, saving another 100g.
Hmm, seems like I am not getting notification emails when new posts are made on this forum.
All this time I was wondering why such a long time to reply, checked manually and you have weeks ago.
Anyway, while I wait for my thumb and index finger to heal, I was doing some engine shopping.
Made a very stupid mistake when I fired up my .91 4 stroke Jap bomber plane, got distracted for a few secs and when I turned back to it, I remembered I needed to remove the glow driver, put my hand straight trough the prop to reach it, and bam....luckily it was running on idle. Valuable lesson learnt! Stay away from the spinning prop as they always say.
Here's my current collection of 4 strokes, some second hand (very low hrs), some brand new.
Those Cox engines, smaller than 0.49 command a very high price nowadays, in fact they are more expensive than OS 4 strokes (if you hunt for a good deal), which is crazy.
I did fire up a Baby bee cox a few weeks back and found it to be one hell of a messy job. Fuel and oil everywhere, I mean I love nitro engines, but this was just too much. Its got to do with them having no exhaust pipe to channel the oil away, and priming is messy too.
I am sure I will get back into them again, for now they have taken the back seat.
Never owned a .20 and would be keen to have one just to be amazed at how tiny that engine really is.
My older boy totaled the trained plane yesterday while training at the club, so now I am after a new foam trainer.
It was just a matter of time anyway, and it did last us a year or novice flying, which is really good.
I may be able to make if flyable again, but any hard landings will break it again.
For fuel, I have just decided to stick with 20% oil, if it has less, I add more castor oil to bring it up to 20%.
I have read engines gumming up (4 strokes) from high oil content, especially the valve rods. They might need a clean every now and then.
We flew my mates nitro plane yesterday as well, after restoring it, and the the whole wing cover came off from one wing after take off.
Landed it safely and its back to the workshop.
Love it!
Love it!
Sorry to hear about the hand, glad it's still all there! I wound up scoring a handful of those little engines for no more than $50 for any of them, figure I can get them running one way or another. Particularly exciting is a TD .020, rotary valve sophistication!
Shown with a VX-18 for scale - one pee wee .020, one TD .020, and a classic .049
I built / have been flying two super-cheap planes, under $100 kits, both of which have had their props, motors, and landing gear repaired or replaced by now, through no crashes, just extra-firm landings.
The second one I built is an odd bird with a laser-cut ply fuselage, no balsa (presumably to save $), and a foam-panel "skin" - only $60 for the kit without electronics, and it handles well in the air, loops and rolls easily and didn't need any trimming out as-built, though I had to improvise a few times and improved on the overall builds with some extra spacers and skinning the coarse styrofoam wing with packing tape. I programmed "flaperons" into the controller too, so I can droop the ailerons 30% in lieu of dedicated flaps.
