Also, by adding the center diff, you add front/rear brake bias and you can also tune your front/rear power transfer via diff oil. Center diffs add a lot by way of performance in the corners and off the line. When you peg the throttle with a center diff, instead of your truck pulling a wheelie on the track, weight transfers to the rear, the front comes up and the front tires spin faster than the rears until the entire truck catches up in momentum. Which, but changing diff oils, you can control how much wheel spin you get in the front.
