- Thread starter
- #41
OK, so the Junsi iCharger X6 battery charger does not come with EC% or IC5 connectors? Will these work? EC5 Connector Does this need to be a female or male connector? I can't tell which one is shown in the link, it doesn't say on the website.
I was looking at the Liperior batteries too and may pick those up. They get some good reviews but gensacearespammers seems to get the best reviews.
I am glad I finally figured out these quoting thing on this forum.
Thanks for all the replies.
As for cables, that charger comes with a lead with the XT connector to plug them into the charger, you just need an EC5 connector to solder onto the other end to mate with your batteries. Just make sure you buy Amass brand connectors. I have never seen that charger before, but it has a whopping 2A balance circuit which is really good, so batteries should charge quickly.
I would also consider getting some bearing lube like Acer's SIN bearing lube, probably some degreaser of some kind (I like to use a 50/50 mix of water simple green consentrate), and maybe some CowRC's Moo-tor Cleaner for cleaning bearings. You dont need that up front but at some point Id look at getting some.
i would look at getting Liperior batteries from RCbattery.com.
