Webbage
After consulting this forum (well, Charlie at least, he seems to be the don ) and a couple of others, I've been overwhelmingly swayed to buy an Axial AX-10. I didn't originally want to as everyone and his dog has one but you get the impression there's a very good reason *why* once you look into it
Soooo... I'm putting in an order with CKRC tomorrow for an AX-10 kit, an Integy 55T motor, a Castle Sidewinder ESC and a Castle-Link USB lead for the PC. That's all I can afford for starters.
I'll keep you updated when the stuff arrives. It'll probably take awhile to cross the pond from the USA.
I plan on narrowing the chassis, installing alu top mounts/servo plate, bent links, changing the Cs and Knuckles for all alu jobs (saves snapping the buggers off when I get wedged) and installing a high-torque servo. It'll all be run off a 3s 11.1V LiPo pack. Currently I'll be using the ProLine FlatIron tyres I already have (as they are on Axial Rims) and probably eventually stump up for some Losi Rock Claws to go with them.
This is a comp rig and my aim is to make it as capable as possible.
