My First 1:10 Crawler Build: Laegendary Grando => Axial SCX10 II
alademann
Hi everyone,
As I mentioned in my introduction thread, I'm building a basher and a crawler for my 2 sons for Christmas.
I'll add some more details about the crawler build in this thread.
It started out as a Laegendary Grando 1:10 that I got an insanely good price on. What I learned is that the Grando is built on the same platform as an Axial SCX10 II. I also learned that Laegendary - seems to have license to resell RiverHobby (VRX / FTX) RC's in the US - like the VRX RH-1052 - which is the exact same as a Grando - minus the shell design.
Anyway, the thing's got a decent 550 motor in it, a 2 speed transmission, triangulated 4 link suspension, steel frame, etc - a decent place to start in my books - especially since my plan was to upgrade lots of stuff right away.
So I started with this Grando:
and I've arrived at this point in the build for how I'll gift it to my kids at xmas:
Here's the full list of what I've done to it that I'll post more details about in the thread over the next few days:
All parts purchased were aftermarket upgrades for an Axial SCX10 II (long wheelbase)
  • 1/4" lift using TREAL aluminum shock hoops
  • Replaced the plastic body mounts with aluminum / carbon fiber ones
  • Replaced the plastic front / rear bumpers and replaced them with aluminum ones, hitch receiver on the rear
  • Added rock sliders to both sides
  • Replaced the plastic drive shafts with aluminum ones
  • Replaced the stock 6kg plastic steering servo with a 35kg brushless metal one: SPT5835w-180.
  • Moved the steering servo off-axle onto the chassis to increase suspension travel / be more realistic
    • Had to swap out the stock steering link with a metal adjustable one to get the geometry correct
    • Had to use spacers on the aftermarket servo mount to get the horn low enough that I only needed one spacer on each side of the steering link connection points to maintain full steering range
  • Replaced the plastic servo horn with a hard anodized aluminum one from Axial
  • Upgraded the H/L Servo from 3kg to 6kg
  • Improved ground stability by adding 50gram 12mm brass hex drive adapters
  • Improved ground stability by swapping out the plastic wheels / tires with 3 piece aluminum bead lock wheels and Duratrax Showdown CR3 Tires
  • Lowered the COG by moving the H/L Servo that was attached above the transmission case to the surface of the rock sliders using a custom mount I came up with using some spare pieces.
  • Lowered the COG / improved balance by relocating the battery in front of the rear axle on a carbon fiber plate
  • Relocated the electronics to an elevated carbon fiber plate near the front axle to make room for a waterproof box for the winch / aux light switch boards.
  • Lots and lots of wire routing / protection / etc to make it rock proof, water proof, etc.
  • Added switched ground effects lighting to the rock sliders and both body support cross-beams
  • Added switched headlights, tail lights, and down-firing rock lights in the front bumper
  • Hand painted diff covers (for now until I grow impatient and buy portal axles)
  • Shaved the body in key areas to make the giant tires not rub
  • Cleaned out the peanut butter from the diff cases and loaded up LucasOil FT 60k diff fluid in the rear, 10k in the front
  • Made custom mounts for roof rack accessories
cool and a different platform than we usually see. Let's see pictures with all the updated parts installed, when you have a second. curious if everything went in clean and if you think the savings was worth it.
Hi everyone,
View attachment 156861View attachment 156860
Do you know if any of the Axial is alternative parts comparable to LAEGENDARY THUNDER 1/10?????
hey op was just curious if you had any pictures on how you moved your steering servo to body mount. I have looked online and I am new to crawlers.
