xmaxx work... I have driven it 3 times and I think I've spent half what I paid for it already in parts... lol! I got it used for $750 with a couple 4S packs, 3S packs and 2 chargers. While working on it tonight, thinking I was done, I noticed the front shock tower is cracked down where the upper hinge pin goes through. DANGIT!
So far:
RPM hinge pins for the upper/lower outer and upper inner. Used spacers to take up the slop on the inner ones (didn't know they weren't all the same). Dremeled down the heads on the upper outer ones for the front so they don't have clearance issues with the steering.
Max6, I had a spare one on hand and didn't care for how the vxl-8s felt. It liked to hesitate on me.
Killed the stock motor the second time out, tried 21/50 gearing and it got hot. Not sure if it was due to the gearing or the motor fan missing half their blades or just how I drive where I drive. Replaced it with a spektrum 5687/1100kv. Bent the stock cooler to fit it and put 2 new 35mm alloy framed rocket fans in it. Started with 25/50 gearing and the punch set to 3-of-6. Did a lot better, but the motor was still warmer than I'd like. Got a new cooler which has open area under the fans, so the air will hit the motor directly more now, also 40mm fans. Also put a 26T pinion on, so it might not be running at WOT so much and run a bit cooler.
M2C mount to fit the larger motor.
A couple Arrma 8mm Safe-D pinions for the new motor.
3D Printed gear cover, not sure if it's necessary... but since there's an open hole under the spur that goes down to the center diff... figured I'd try and put something on it to block grass/rocks getting easy access.
Added a small cap pack to take some load off the onboard caps.
Replaced the lower front arms, busted one and the other was pretty banged up. Got the red HD ones.
Replaced broken upper chassis brace.
Installed metal gears into the stock servo.
HD Servo saver spring/turnbuckle.
Replaced broken front/lower bumper mount.
Removed the SS alloy center skids that were on it. They were heavy and where I drive, not really necessary.
Roof skid, the traxxas body washer bits as it didn't have either of them.
Even with all that, I'm really enjoying launching this thing! Just wish it didn't sound like your slamming a dumpster lid every time it lands... lol!
