vxl on 3s
Nice kit. I like the shock guards. H@!! I like the whole thing. What speeds are you getting.
---------- Post added at 8:32 AM ---------- Previous post was at 8:29 AM ----------
I dont have castle softwate to adjust punch.
Then Id suggest some weights or maybe some less agressive tread pattern tires. Shes Still a work in progress as I'm tuning it in for 100+MPH runs but right now the weight distribution is off...I'm still trying to figure out something that works better. I think the best speed I've managed so far without crashing is about 86MPH. can't run it when its cool/cold outside as the tires dont grab enough traction and the kit is brittle if its to cold. I'll resume my quest on it this spring when it gets nice and warm.
greywolf did the mamba monster 1/8th scale bolt right on or did you have to buy a convertion kit to make it fit?
You have to buy a transmission case with a flat aluminum motor mount to get it to fit and you have to dremel out the lower screw hole where it slides especially if you start putting large pinions on it like I have.
