mjx 16210 3s battery
asaf
hi guys i bought mjx 16210 hyper go 7.4v
i would like to know if i can put 3s baterry on the 7.v mjx 16210
will it work or will it braek the car?
originly it comes with 2s batterry
thanks
Welcome to RCTALK.COM!!!
Usually when a car is offered in 2 different power versions, there will be some difference in the electronics, gearing, axle and other upgrades.
I don't own one of these so I can't 100% confirm.
Do you have a manual that came with the truck?
There should be some info in that.
Thing is, even if the electronics can take it, the car might need upgrades so it doesn't blow itself apart. Metal gears, full bearings etc.
I think @Hornet68 could offer some help here. He's a fan of the Hyper if I recall correctly. 😎
Welcome to RCT. Going up in power on a RTR, as Mike said, will likely require other upgrades. That's if the electronics don't burn up, which is likely.
thanks
Welcome to the RCTalk fold.
Those MJX Hyper Go platforms should state 2S/3S compatible with the 45amp ESC.
If you are going to do 3S LiPo battery, with existing motor, I would keep in mind a larger gearing ratio (smaller pinion gear) may be needed to compensate a bit.
Just run it as is and get a proper platform when you want to upgrade. What you're trying to do, as they would say in my language, is make a turd pie.
