- Thread starter
- #21
It does look like a pretty good bang for the buck. Probably will get that one
Grab it. That's a great deal on a charger that is better than the D300.I found a new HOTA D6 Pro for $90. Good deal? Cuz I do have my eye on an IMARS D300. What do y'all think?
Yes, I'm aware that Europe uses 220v and 50hz for power. Charge cables aren't really a worry for me. I just figured out a way to charge my Traxxas 3S pack with my Shark robot vacuum base charger. It uses 3 18650 batteries in its pack so 3S. It's almost done too. All goodD6 Pro is AC.
Be sure to buy the US version. EU will have different plugs, voltage...
You'll want to buy appropriate charge cables for your batteries too.
The charger is sold as 2 different versions. The Eu version is usually cheaper.Yes, I'm aware that Europe uses 220v and 50hz for power. Charge cables aren't really a worry for me. I just figured out a way to charge my Traxxas 3S pack with my Shark robot vacuum base charger. It uses 3 18650 batteries in its pack so 3S. It's almost done too. All good
Probably the chinesium in the circuit board.My Traxxas charger smelled toxic for about the first 20 uses. Had to keep garage door open and large fan going. No smoke or excessive heat, just really stinky.
The 'Traxx' isn't so bad but the 'as'...well, it smells like ass.Probably the chinesium in the circuit board.
Same. Always like burning plastic or wire insulation. I know the smellMy Traxxas charger smelled toxic for about the first 20 uses. Had to keep garage door open and large fan going. No smoke or excessive heat, just really stinky.
That's a sure sign they used the bare minimun electronics in the charger. The resistors are likely running at their limit, and are offgassing the products used to make them. Ever smelled a capacitor or resistor pop? It could be chemicals they use to make the PCB as well.Same. Always like burning plastic or wire insulation. I know the smell
The AC/DC version is called the "PRO"The cheapest I found the DC only version is $84.
The cheapest AC/DC combo version is $107.
Both look identical besides the A/C plug on back left side. Why they're both called a D6 without a special version designation letter or number? Idk
