Revo Rancher
Geeez, I go away to do some work and take a 10 minute nap and spitfir is running in the A-mains! Great! You are going to shock your dad because the last time he saw the rig he got blisters from trying to help you start it.
When you get time to try the next step, do the same thing, 3 second throttle runs, then brake, but this time vary it from 1/3-1/2 throttle. Do this one tank. Right now you are thinking, "Why can't I lean it?". Believe it or not, everytime the tank gets low on fuel the fuel mixture gets leaner in the carb (long explanation, don't ask why). So, if the car makes it through one more tank of 1/3-1/2 throttle blips without engine trouble, then we will lean it some more since it just ran lean at the end of that last tank and ran fine.
Add another tank of fuel, turn the top end needle, usually the one highest and easiest to see, 1/8th of a turn to the right or clockwise. Go through that tank with 1/2 throttle, 3 second bursts. If all is well, and you still have blue smoke coming out the pipe, lean it another 1/8th and do 5 second half throttle blips. If all is well, try another tank and see if you can get as much throttle as you can handle up to 3/4.
If you can't, we'll take you to the next step. If you can, then we'll try to performance tune it and then you will be on your way.
In the future, once it is broken in, it should start within 2-3 pulls, idle nice, and only need one needle adjustment, barely, one way or the other. You are lucky, you are in Florida where the weather is much more consistent. (Like us in So Cal)
BTW, somewhere along here it is entirely possibly you're break-in glow plug may foul badly or just quit. I would have spare plug on hand. Usually the first sign is that engine starts to act up, not idle, quits at half throttle almost consistently, won't even try to fire off, a variety of things.
Believe or not, the break in period is good for the driver, too. It slowly gets you used to the handling and other quirks of the rig. (that reminds me, watch your batteries; if they go low, the car could take off on you with no way for you to control it as you cannot communicate to it via the radio)
