WickedFog
Community Leader
RC Showcase: 9
- Terre Haute, IN
- Crawling
- Scale Builder
- Thread starter
- #61
Yeah, same here. That is a 2 piece cover. So the front half with the diff was the priority.Looking good man!!
Everyone does things differently, but a lot of times yielding the same result. If itās lights, itās a star pattern, or criss-cross. Anything else, and I start in the center, and work my way in a spiral to the outermost fasteners. Either way, itās three passes until desired torque, bolt stretch, or whatever it calls for.
i always mount those with ON facing the rear if possible (if I even use that switch in anything). I've never had a crash turn one off. I have however had grass and twigs turn a car off on multiple occasions when I had ON facing the front.Also itās tough to make out-but LOOKED like your switch has āONā facing the rear of the vehicle. If thatās the case, Iād strongly recommend that ya yank the screws, and rotate it 180deg. If running a mechanical switch (I always delete mine prior to install to eliminate a possible failure point), you always want āONā facing forward. This way in the event of a crash, or hard hit, lawn dart, etc., the vehicle doesnāt turn off. Seen it happen about a gazillion times. If I misread what looked to be āONā just outside the metal bezel, and itās facing toward tue front, obviously disregard.![]()
But regardless, I already have replacement switches for those, because I freakin' hate those switches because of the whole accidental shut down due to debris. And I already have a mount designed to mount the switches I have. I just need to modify it for this vehicle. I just mounted it to keep my wire from untwisting
It's in my cartYouāre moving right along man!! Looking absolutely tremendous!! Get you some dammiit ice cream fella!!![]()
