when we release our part next week, I would definitely consider it. I designed it so that you could run a stock chassis, stock suspension setup and still have a capable crawler that wouldn't harm itself because of its inherent flaws. Other than that, get some weights on those wheels, more weight in the front, and that's about it.
Oh yea, make sure you have the goat in the second crawler setting. It's throttle and braking curves are smoother and it will help with the rough startup. Other than that, set your drag brake. I assumed that the default drag brake would be decent, and it hurt me in the comp because unless you specifically set the drag brake, it has almost none.
