Oops, I probably should've mentioned - the included black o-ring isn't that great, I'd recommend using the orange one from the original fuel cap.
I'd also recommend using the original silver "pressure fitting" instead of the black one they include to connect the pressure line, and if you can use a little silicone or an o-ring to seal that too, it also leaks a little. I know I talked about how much better they are than stock, but that's after you iron out the kinks, sorry I didn't include that in my recommendations.
I actually bought my own o-rings, the one to seal the tank cap is
23mm OD * 2.4mm, and the one for the fuel nipple is
4mmOD x 1mm, both in red silicone. It was under $5 from aliexpress for baggies of both.
...I also used some silicone between the fuel tank and the silver insert inside it that holds the o-ring.
I feel bad having recommended them without including all these caveats... also, I just bought myself some stainless steel m2.5x4mm screws because the included carbon steel ones look like they're rusting from the nitro. Things I've discovered since we last talked...
Yes, if you've split the top deck the way we previously discussed in this thread, the only thing you need to remove is the front half of the top deck with the fuel tank, and leave the servos / radio tray / everything else in place. Re-seating the dogbones as you get the transmission in can be a little tight, but still was easier than dismantling the rear half.
The flat spots are in the same orientation along the entire shaft, so you can use the drive cups / flats on either end to align it correctly.
That little clutch piece can be a headache to diagnose / fix, I've found that pressing the insert on the side that drops in with a little tuning screwdriver to feel the resistance is a good intermediate test for whether it's working right or not.
Unrelatedly, I've been slowly dipping my toes more into the brushless scene, and I think I may have been too pessimistic about its potential last time we spoke - I've discovered
a few more gears that I think would work, and come to understand power available in a brushless a little better. With a 3900kv motor on 3s and fat gearing, it could probably do 60 easily. I agree that the nitro->brushless conversion would be a better electric car than the electric version, primarily for the pivot ball suspension, but also because I'm pretty sure you could fit a longer motor than the brushed one accommodates.
I got my stock Flying Fish up to 47mph with those solid-axle diffs and its VX18, and my custom-built one up to 48mph on its .12 engine.
