tudordewolf
You didn't have to heat up the crankcase to insert the bearing in?
Man I have been having this one issue with my FFish that followed me trough all my builds and I never managed to figure out what it is. Even with the old VX engine.
When the fuel tank gets about about 1/4 I start getting massive air pockets in the fuel line, in fact sometimes they are so big, that the car will just starve of fuel and shut off on me.
Fuel system is absolutely air tight, and this only happens after a WOT. If I hold the car in my hand, its fine, let it go and come back, there's air pockets.
I have just moved the fuel tank below the top plastic bracket that holds it, thinking its that, as I had it mounted on top. No difference.
Maybe the exhaust pipe is not providing enough pressure to the fuel tank once it gets near empty?
I don't know, but car sounds like the tune is off when this happens.
I warmed it with a heat gun, placed the bearing on the crankshaft and used that to line it up and insert it, and it popped in as easily as a wheel bearing. I was a little surprised, it didn't take any force at all to seat it, the SH.12 I'd done a few days ago had more of a "pop," and I preheated that too.
I've had similar issues with the fuel line drawing air, I think that's part of the reason I like to keep the tank over 50% full. I can only guess that the sloshing & vibrations from driving are foaming up the fuel enough that it's sucking up air bubbles before running out.
I'll add about the under-mounting, I "sandwich" my fuel tank between o-rings for extra vibration dampening. This also lowers it such that the bottom of the fuel tank and overflow tube both sit "in" their cutouts in the chassis, which I find satisfying. On the other hand, it may be transferring vibrations into the tank through the bottom as a consequence, but I haven't had any air bubble issues in a while. I also ditched the inline fuel filters, because when I was having air-bubble issues, it seemed like those would "gather' little air bubbles and then release them all at once as a big air pocket and stall the engine. I had them mounted horizontally, maybe they wouldn't do this if they were vertical.
Like I said though, I tend to top every few minutes, so I may have just squashed it the blunt-force way, and it's possible nothing about my physical setup changed any of that.
