kx250ryder
Derek's points have made sense to me since page 1 of this thread(and I never read the article). By removing the pressure line, you add low end response, remove some of the midrange hit, and lower top end revs slightly.
Because they (XRC) wrote this article, another company has decided to create a product that both gives a "no pressure line" effect at low RPM (to gain more bottom end), and a "pressure line installed/richened HSN" effect at high RPM (to gain horsepower on top and increased revs).
My guess is that the device does one of 3 things to decide when to adjust fuel pressure to get more peak power:
1.) Monitors engine RPMs via a sensor on the flyhweel or clutch bell
2.) Monitors servo position to check for full throttle
3.) Monitors exhaust gasses for increased pressure
It probably uses some sort of valve with variable opening, by closing it off at low RPMs, you get the "no pressure line" boost to bottom end power. At mid-top RPMs it probably opens up allowing pressure through or perhaps somehow forces addtional pressure beyond what is normal (such as a battery powered fan or fuel pump).
