No go new clutch but won’t power on just revs out
Shoes should still grab backwards. I believe theyre actually supposed to grab harder backwards.
Couldn't remember. Had to check the hudy setup Bible lol
Until I read Beer Goggles post, I just assumed that there was only one way to install them (trailing shoes).
You learn something new every day.
Some questions:
1. Aluminum or composite shoes?
2. Did your clutch shoes come with multiple springs?
- Maybe try thinner springs?
3. Did you remove and reinstall the flywheel?
- Is the flywheel gripping the collet?
- The clutch nut may need to be torqued down a bit more.
- I had run a flywheel for a long time on an engine that eventually "swallowed" the collet so that it no longer gripped the collet.
The engine revved, but no go...
I could not tighten the clutch nut enough for the flywheel to grip the collet.
I can't remember if I went to a larger collet or replaced both the collet and flywheel to remedy the issue.
Probably the latter.
4. Can you post a pic?
Some questions:
Yes this is correct iv installed them in Trailling I’ll get some video of it running to show you..
Yes I did install the flywheel alto When I spin the flywheel by hand the engine turns over so I think it’s tight enough what are your thoughts ?
I only got one set of spring as I ordered them on line but they seam to be very strong but I didn’t have any thing to go off as they weren’t on the engine beforehand
Some questions:
Iv taken a 20 second video but can’t upload it only photos
