i need help chragin battery
Wow, that is a big battery. I would charge it as hig a rate as you can or it will take forever to charge it up.
Looking at the Brain's specs--max is 4.5 amps. It may be enough...
I believe that is a gel cell right? If so, the 960 isn't able to charge it. You may have to buy a wall charger for it or upgrade.
Either "will work" as long as the voltage output of the charger matches that of the battery.
Amps are not the issue voltage is when it comes to charging. Lower amps mean a longer charge cycle but with better performance from the battery. Higher amps mean quicker charge rates but the batter charge may not last as long or battery life may not last as long with a higher amp charger.
I use a car charger on a 2amp trickle.
That battery is equal to a 10 cell battery pack. (1.2v X 10)
I dont think either charger is rated for 10 cells.
That was what I was wondering about. I believe this one will work:
http://www.batterymart.com/p-cliplight-12v-6a-gel-battery-charger.html
Product Description:
Good for any Gel battery above 20 amp hours
Comes with a 6' AC power cord and 6' DC cord with alligator clips
12 VOLT / 6 AMP: Microprocessor based charger for applications from charging to maintenance for small to large batteries commonly used in; On-board and Off-board applications, specially designed for electric scooter, power wheel-chairs and patient lifts among others.
GENERAL SPECIFICATIONSOUTPUT: 12 volts nominal / 6 Amps N.B. Voltage Levels and charge algorithms may be preset to Customer Requirements
INPUT: Universal / IEC plug 90-245Vac, 50-60Hz
MECHANICAL SPECIFICATIONS
DIMENSIONS: 4.25" wide x 1.75" high x 6" deep 10.63cm x 4.38cm x 15cm deep
WEIGHT: 3lbs; 1.36kg
FEATURES FULL 3 LED DISPLAY: 1st L.E.D. indicates power on, 2nd indicates battery charging, 3rd indicates battery is fully charged and charger is in float/maintenance mode.
CONSTANT CURRENT STAGE: Charges at Constant Current until the bulk charge is done and then switches to the Constant Voltage Stage.
CONSTANT VOLTAGE STAGE: Charges at Constant Voltage until the battery system is fully charged then switches to the Float Mode.
FLOAT MODE: The charger maintains the battery and monitors its capacity.
USER FRIENLDY FUSE SYSTEM: The design allows easy access to all fuses without disassembling the charger. The line-input fuse is integrated with the IEC universal plug and carries also with it a replacement. The output fuse is located beside the output connectors and is an easily replaceable ATC automotive fuse.
SWITCHMODE TECHNOLOGY: Charger uses much less power than standard linear chargers and the design has an above 78% efficiency. Full metal (aluminum) housing reduces E.M.I. emissions drastically.
NOTE: Regulating Parameters, Charge Algorithms, Output Lead Assemblies and Accessories can be altered, at the factory, to suit your particular application and requirements. Call today to receive a personalized quote and/or to speak with one of our representatives who would be happy to help you with your application questions.
1 Year Warranty
i would get a charger for it thanks is only $10 for it thanks alot for the help guys
