HPI Nitro RS4 Mini build #2
Defiant
  3. Flying
This is going to be a fully upgraded nitro mini build with tons of carbon!
This is what I got so far
Everything is kind of temporary, for example:
-the gearbox will be completely rebuilt with new gears and the shaft micro polished
-purple washers and standoffs will be replaced with another color (thinking red maybe?)
-pulleys and mounts will be alloy
-rear brace will be carbon
Check out this brake disk though
I'm starting to not like you. 🙃 I can't wait to see what you piece together.
Stripped it down to just the chassis in preparation for some new parts. I scored a bunch of HPI carbon graphite parts (hence the silver paint over the part number)
I took a pic with the flash on to show the carbon graphite (left) next to the stock plastic bulkhead (right)
Also got a full set of CVDs for this builds, didn’t think I’d ever find a set but sometimes you get lucky!
No belts unfortunately
I’ve been saving these, black hpi mini wheels 😍
Put some new tamiya m chassis tires on
Most of these parts are carbon graphite apart from the suspension arms and c hubs
To be continued…
I’ll be honest I’m a little tired of this build, it’s been 99% frustration but regardless the mini build marches on…
I somehow did the impossible and found a NIP foam bumper for sale and snagged it
Along with some genuine hpi mini tires to replace the Tamiya M chassis tires I put on the car earlier
Got the mid shaft cleaned up for install
Put in a new front diff and belt, front diff housing and even a Kose belt tensioner
Didn’t put the small pulleys on yet because I don’t want stock ones…
Check the genuine tires
Who produces the washers you use?
Defiant
Replies
Defiant
Defiant
Defiant
Replies
8
Defiant
Defiant
coldvod
Replies
12
coldvod
coldvod
