i was wrenching tonight, did half of it backwards... this is the way for me lol. i just sort of go for it. i sometimes have extra screws which is pretty scary
for me it depends on what I'm fixing, the more i do it the more i understand on it and the fewer extra screws i get.... sometimes.
watching you tube vids is sometimes helpful, posting a pic here of my confusion usually clears it up. someone on here has already done what I'm trying to do, but by now they can do it blindfolded lol
it does get easier as you repeatedly take the same part off and put it on wrong 2 or 3 times
i often take pics. ( if for no other reason that it helps to spruce up my build threads lol) i forget what direction my motor goes pretty often lol, and sometimes specific screws go in specific spots. sometimes it doesn't seem to matter as it may use 12 of the same screw.
axial for instance on the transmission, 2 of the 4 screws holding it in are longer. so i put a piece of tape with arrows pointing to the proper holes for the long screws, makes putting it back together easier. my cen on the other hand it uses the same 4 screws to hold the transmission in place.
i also use different pans for different things with a little paper label so i remember these are transmission screws, this is from steering blocks, so on and so forth. if the screw has a nut ill put the screw where it lives ( thru the rod end typically) and put the nut on so i always know where that long screw goes since its already there.
but most often i just do it wrong, realize somethings not right then i pop open the exploded view and will track down the issue that way often.
tonight i was trying to connect steering blocks, but my axle doesn't seperate for me to add them. was saddened. but i just put what brass i was able to on and threw the rest in a bag for some other project someday lol
the more you wrench the more it makes sense and the easier AND more rewarding it becomes.
tis a good feeling to diagnose the problem, get the parts AND fix the problem. it comes with a nice sense of accomplishment.
you just gotta get dirty lol
i have a bookmark set for each of my trucks. need to work on the ascent? click the ascent bookmark and it opens me right to the exploded view. same with all my trucks. makes everything easier. much less hunting around, find it once and save it
i click that, it takes me to this
i scroll down to the part thats broken and theres the replacemnt part number, i can click it and go straight to it, makes diagnosing and replacing much faster for me this way.
\much much less searching since its already saved
