i bought new esc 120A and new motor 2845-5900kv surpass when i connect it to remote The engine spins freely, but when I hold the gear, it gets stuck at one point, starts vibrating, and loses power. what could be a problem
i bought new esc 120A and new motor 2845-5900kv surpass when i connect it to remote The engine spins freely, but when I hold the gear, it gets stuck at one point, starts vibrating, and loses power. what could be a problem View attachment 278303View attachment 278304
That's normal, it's called "cogging", and it is what happens if you overload a brushless motor. (sensored ones can keep pushing but you shouldn't overload those either)
Are you using the correct battery? Is it fully charged? Is your esc programed correctly?
Do you have the low voltage cutoff set for the battery you are using?
Welcome to our comprehensive RC batteries and motors resource hub designed to help you get the most out of your RC experience. Whether you're a seasoned veteran or a newcomer to the world of radio-controlled vehicles, this thread aims to provide you with all the essential information and expert advice you need.
Low voltage cutoff is when your esc detects the minimum voltage of your battery. Looking at the picture of your battery i can not tell if its a 2s 3s or 4s. Usually esc's need to be programmed and calibrated. So if the esc is set for 3s and your running 2s battery it will think voltage is low. Did you follow the setup directions? Have you calibrated forward, neutral and reverse with your transmitter? Is your battery charged?
I'm sorry, but that ESC is the absolute worst thing I have ever used .
There is no throttle calibration to be done on them. You just set your radio's throttle endpoints to 100% and the speed control looks for neutral point when you turn it on. It never worked right for me. Some people report they only work with certain radios. I should have tested it before mounting on my RC. Thankfully, seller refunded without any hassles. I wouldn't put it past the ESC as being the cause of your troubles.
I got that one by mistake. I thought I was getting one of the "blue 120A" ESCs that I have used many times before... the ones that have a setup button on the on/off switch (like shown below).
in addition to what everyone else said, @lukaa when you said the car "won't run", have you tried putting the car on a raised platform (as long as the tires aren't touching the ground) and check if it still refuses to run?
