The Ultimate Guide to Lithium Polymer (LiPo) Batteries for RC Enthusiasts
Greywolf74
I'M TO BLAME!
Lifetime Supporter!
Ohio
Welcome to the comprehensive guide on Lithium Polymer (LiPo) batteries tailored for RC hobbyists. This guide will cover everything you need to know about LiPo batteries, from their structure and specifications to safety practices and common FAQs. Whether you’re a beginner or an experienced user, this article aims to provide all the essential information to help you get the most out of your LiPo batteries.
Understanding LiPo Battery Basics
What Are LiPo Batteries?
LiPo batteries are a type of rechargeable battery that has become the standard in the RC hobby industry due to their high energy density, lightweight design, and high discharge capabilities. Unlike older Nickel-Metal Hydride (NiMH) batteries, LiPo batteries use a polymer electrolyte, which allows them to be made in various shapes and sizes.
How Do LiPo Batteries Work?
A LiPo battery consists of multiple cells, each with a nominal voltage of 3.7 volts when at rest and 4.2 volts when fully charged. Nominal voltage is the average voltage that a battery cell operates at during typical use; for example, even though a cell might range from 4.2 volts when fully charged to around 3.0 volts when discharged, it commonly operates around 3.7 volts.
This nominal voltage is used on battery labels to provide a standardized reference point for comparing and identifying batteries. These cells are composed of a positive electrode (cathode), a negative electrode (anode), and a polymer electrolyte. The configuration of these cells within the battery pack determines the overall voltage and capacity of the battery. Using nominal voltage is practical because it represents a consistent value for users and manufacturers to understand and communicate the battery’s performance characteristics, ensuring compatibility with devices and charging systems.
Series (S) Configuration
When cells are connected in series, the voltage of the battery pack increases while the capacity (mAh) remains the same as a single cell. The series configuration is denoted by the letter 'S'. For example:
  • 1S: A single cell with a nominal voltage of 3.7V.
  • 2S: Two cells in series, resulting in a nominal voltage of 7.4V (3.7V + 3.7V).
  • 3S: Three cells in series, resulting in a nominal voltage of 11.1V (3.7V + 3.7V + 3.7V).
The series configuration is commonly used to increase the voltage to match the requirements of different RC models, providing more power for high-performance applications.
Parallel (P) Configuration
When cells are connected in parallel, the capacity (mAh) of the battery pack increases while the voltage remains the same as a single cell. The parallel configuration is denoted by the letter 'P'. For example:
  • 1P: A single cell with a specific capacity (e.g., 5000mAh).
  • 2P: Two cells in parallel, resulting in double the capacity (e.g., 5000mAh + 5000mAh = 10000mAh) while maintaining the nominal voltage of 3.7V.
  • 3P: Three cells in parallel, tripling the capacity (e.g., 5000mAh + 5000mAh + 5000mAh = 15000mAh) while keeping the voltage at 3.7V.
The parallel configuration is used to increase the battery's capacity, allowing for longer runtimes without altering the voltage.
Combined Series and Parallel (S/P) Configuration
Many LiPo battery packs use a combination of series and parallel configurations to achieve the desired voltage and capacity. This is represented as 'S' followed by 'P'. For instance:
  • 3S2P: This configuration indicates 6 total cells. If you wire up 2 cells in parallel a total of 3 times, and then took those three pairs of parallel cells adn then wired them all up in series you would have a 3S2P LiPo which has a total of 6 cells in it. The nominal voltage would be 11.1V (3.7V x 3) with double the capacity of a single cell pair. Does that make sense? If not feel free to PM me and Ill break it down better.
By understanding these configurations, users can select the appropriate LiPo battery packs for their specific RC applications, ensuring they meet the voltage and capacity requirements for optimal performance.
Key Specifications and Performance Metrics
Voltage Configuration
The total voltage of a LiPo battery pack is determined by the number of cells connected in series (S). Here are common configurations:
  • 1S (3.7V): Single cell
  • 2S (7.4V): Two cells in series
  • 3S (11.1V): Three cells in series
  • 4S (14.8V): Four cells in series
Capacity (mAh)
The capacity of a LiPo battery, measured in milliamp-hours (mAh), indicates the total charge it can hold. A higher mAh rating means the battery can provide more current over a longer period. For instance, a 5000mAh battery can theoretically provide 5000mA of current for one hour.
Discharge Rate (C Rating)
The C rating of a LiPo battery indicates the maximum current it can safely discharge and is expressed as a multiple of the battery’s capacity. For instance, a 5000mAh battery with a 25C rating can theoretically discharge at a maximum of 125A (5000mAh x 25 = 125,000mA or 125A). High C ratings are crucial for applications that require rapid bursts of power, such as high-performance RC models.
Understanding C Ratings
C ratings help users determine the current a battery can handle without overheating or suffering damage. The rating includes two parts:
  1. Continuous Discharge Rating: The maximum current the battery can discharge continuously.
  2. Burst Discharge Rating: The maximum current the battery can discharge for short bursts, usually a few seconds.
Industry-Wide Inflation of C Ratings
It is widely recognized that all manufacturers in the LiPo battery industry tend to inflate their C ratings. This practice is done to make their products appear more powerful and attractive to consumers. Here are key points to understand about this issue:
  1. Overstated Ratings: Manufacturers frequently exaggerate C ratings. A battery advertised as 50C might realistically handle only 20-30C under safe conditions.
  2. Inconsistent Testing Standards: There is no universally accepted standard for testing C ratings across the industry, leading to significant variations and inflated ratings.
  3. Real-World Performance: In practical use, many batteries do not perform as advertised. A battery rated at 50C may not sustain the required amperage for extended periods without significant voltage drop or failure.
Practical Approach to C Ratings
When selecting a LiPo battery, it is essential to approach C ratings with skepticism and caution:
  • Conservative Selection: Choose a battery with a higher C rating than your application requires to provide a safety margin. For example, if your application needs 100A, select a battery rated at 150-200A.
  • Realistic Expectations: Understand that the actual performance of the battery might be significantly lower than the advertised C rating. Plan for this discrepancy to ensure your application operates reliably.
  • Heat Management: Be mindful of the heat generated during discharge. Even batteries with accurate C ratings can overheat if pushed to their limits continuously. Ensure adequate cooling and avoid operating at maximum discharge rates for prolonged periods.
Understanding the limitations and universal exaggeration of C ratings helps in making more informed decisions, ensuring better performance, longevity, and safety of your LiPo batteries in RC applications.
Safe Handling and Usage
Charging
Proper charging of LiPo batteries is crucial to ensure safety and longevity. Always use a Constant Current Constant Voltage (CCCV) charger designed specifically for LiPo batteries. Here are key considerations when choosing a charger:
AC vs. DC Chargers
  • AC Chargers: These plug directly into a wall outlet, making them convenient for home use. They also offer the flexibility to be taken to the track, providing versatility for RC enthusiasts who need a reliable charging solution both at home and on the go.
  • DC Chargers: Require an external power source, such as a car battery or a dedicated DC power supply. These chargers are generally more portable and offer higher power output. The most powerful chargers are typically DC only, as they can be paired with high-capacity power supplies to deliver the necessary wattage for fast charging large battery packs.
Overall Wattage and Balance Current
The speed at which a charger can charge a LiPo battery is determined by two main factors: overall wattage and balance current.
  • Overall Wattage: This determines the maximum power the charger can deliver. Higher wattage chargers can charge batteries faster. For example:
    • 50W-100W Chargers: Suitable for smaller batteries or for users who do not need fast charging.
    • 100W-300W Chargers: Ideal for most RC hobbyists, providing a good balance between charging speed and practicality.
    • 300W+ Chargers: Best for those who need to charge multiple large capacity batteries quickly, often requiring a high-capacity DC power supply.
  • Balance Current: This is the current used to equalize the voltage across all cells in a battery pack during balance charging. Higher balance currents allow the charger to balance the cells more quickly, reducing overall charging time. Look for chargers with higher balance current ratings to enhance charging efficiency.
Key Features of CCCV Chargers
  1. Constant Current Phase: Initially, the charger supplies a constant current to the battery until it reaches its peak voltage (4.2V per cell for LiPo).
  2. Constant Voltage Phase: Once the peak voltage is reached, the charger maintains a constant voltage while gradually reducing the current. This phase continues until the charging current drops to a predetermined level.
Balance Charging
Balance charging ensures that all cells in a pack are charged equally, preventing overcharging or undercharging of individual cells, which can lead to reduced battery performance or safety hazards. Key aspects include:
  • Balance Current: Higher balance currents can significantly reduce the time required to balance charge the cells, enhancing overall charging efficiency.
  • Balance Ports: Ensure your charger has appropriate balance ports for the types of batteries you use.
By understanding the importance of overall wattage and balance current in chargers, and choosing the right CCCV charger, you can maintain the safety, performance, and longevity of your LiPo batteries. This comprehensive approach ensures efficient charging and optimal battery health.
Temperature Monitoring
Avoid excessive heat during charging and discharging, as overheating can damage the battery or cause it to become unstable. The best way to make sure your LiPos are not overheating is with an IR temp gun. Any cheap IR gun will do. Also, always charge and store batteries in a cool, dry place.
Storage Guidelines
Store LiPo batteries at a voltage of around 3.85V per cell. This storage voltage helps prolong the lifespan of the battery and prevents degradation. Keep batteries in a fireproof container to minimize risk.
To maintain battery health during long periods of inactivity, cycle your LiPo batteries once a year. Cycling involves fully charging and then discharging the battery to its storage voltage. This practice helps prevent the buildup of internal resistance and keeps the battery cells balanced and functioning optimally.
By incorporating cycling into your yearly maintenance routine, you can ensure that your LiPo batteries remain in good condition, ready for use when needed.
Best Practices for LiPo Battery Usage
Regular Voltage Checks
Regularly monitor the voltage of each cell to ensure they remain within safe operating limits (typically 3.0V to 4.2V per cell). This practice helps prevent deep discharges, which can permanently damage the battery.
Discharge Management
Avoid discharging the battery below 3.0V per cell. Deep discharges can significantly reduce the battery’s lifespan and performance. The primary way to prevent over-discharging a LiPo battery is by properly setting your LVC (Low Voltage Cutoff). LVC is a feature in most electronic speed controllers (ESCs) that automatically reduces power or shuts off the battery when it reaches a certain voltage, protecting it from damage. It is recommended to set the LVC between 3.2 and 3.6 volts per cell, with most people erring on the side of caution at 3.6V per cell. Setting it higher is advisable because voltage sag during high power draw can temporarily drop the voltage below the set LVC, potentially causing damage.
As a secondary measure, especially if you are using an ESC without an LVC feature (or not using an ESC at all), you can use a LiPo alarm. This device monitors the voltage of each cell and alerts you when the voltage gets too low, allowing you to stop using the battery before it gets damaged. By using these methods, you can ensure your LiPo battery maintains its performance and longevity.
Physical Inspection
Inspect the battery regularly for signs of swelling, damage, or punctures, which can indicate a compromised cell. Damaged batteries should be handled with care and disposed of properly.
Understanding LiPo Internal Resistance (IR)
What is LiPo Internal Resistance?
Internal resistance (IR) in a LiPo battery is the resistance within each cell that impedes the flow of current. It is a crucial indicator of the battery’s health and performance. High IR can lead to reduced efficiency, increased heat during discharge, and potential damage to the battery.
How to Measure LiPo Internal Resistance
To measure IR accurately, you can use a dedicated battery analyzer like the LiPo ESR Meter Mark II from Progressive RC, or a charger with an IR measurement function. While battery analyzers provide the most accurate readings, chargers' readings are acceptable for regular monitoring.
What Information Can Be Gleaned from IR Measurements?
  • Health Check: Low and consistent IR values across cells indicate a healthy battery. Significant variations or high IR values suggest cell imbalance or degradation.
  • Performance Prediction: Lower IR results in better performance, as the battery can deliver higher currents more efficiently.
  • Heat Generation: High IR causes increased heat generation during discharge, which can be detrimental to the battery’s longevity and safety.
Additional Information on IR
  • Temperature Effects: IR increases with temperature, so always measure IR at a consistent ambient temperature for accurate comparisons.
  • Aging: IR naturally increases as the battery ages and cycles through charges. Monitoring IR over time can help you predict when a battery is nearing the end of its useful life.
  • Balancing: Regularly measuring IR helps in balancing the cells more effectively, ensuring even wear and optimal performance.
Commonly Asked Questions About LiPo Batteries
1. How do I choose the right LiPo battery for my RC model?
  • Answer: Select a battery that matches the voltage and capacity requirements of your RC model. Ensure the C rating is sufficient for your model’s power demands. Always refer to the manufacturer's specifications for recommended battery configurations.
2. How should I store my LiPo batteries?
  • Answer: Store LiPo batteries at a voltage of around 3.85V per cell. Keep them in a cool, dry place, ideally in a fireproof container. Avoid storing them fully charged or fully discharged to prevent degradation.
3. What are the signs of a damaged LiPo battery?
  • Answer: Signs of a damaged LiPo battery include swelling, punctures, and visible damage to the cells. If a battery becomes hot to the touch during use or charging, this may also indicate damage. High internal resistance (IR) is another indicator of damage or degradation. Damaged batteries should be handled with care and disposed of properly.
4. How do I safely dispose of a LiPo battery?
  • Answer: Discharge the battery completely and then submerge it in saltwater for a few days to neutralize the remaining charge. After this, the battery can be taken to a recycling center that handles electronic waste. Never dispose of LiPo batteries in regular trash due to the risk of fire.
Conclusion
LiPo batteries are integral to the performance and efficiency of RC models, providing the necessary power and lightweight characteristics for optimal operation. Understanding their technical specifications, including internal resistance (IR), and adhering to proper handling and usage guidelines ensures safe and effective use, maximizing both performance and battery lifespan. For detailed technical information and safety guidelines, consult manufacturer documentation and specialized RC hobby resources.
great writeup!
It might be worth pointing out that power supplies for DC chargers need to be overrated by as much as 25% to account for charger inefficiency. Not all chargers carry the same efficiency so this is a variable.
For example, a 500W charger can pop the breaker on a 500W supply because it can potentially draw up to 625W (i.e. 500W+25%) in order to push 500W of power toward the output into the battery that is being charged at the 500W spec. This is an extreme case, but you never want to push a supply to it's limit regardless or you risk causing excess heat and premature failure of your supply. I always carry a spare supply with me because you never know how long they'll last, more info here on the supplies I like to run:
https://www.rcgroups.com/forums/showthread.php?3460681-How-To-Convert-HP-Power-Supply
Good sticky. Lots of good stuff here.
Question. What part does rated battery wattage have to do with performance battery selection? Rated wattage appears on many battery cases along with C-Rating. Why is that an important part of the selection process?
Long have I bought all the "C" I could afford when purchasing a LiPo's. 2S Lipo's are my track standard, although I do have one 3S in the inventory. Having second thoughts about that now and looking at further purchases by selecting wattage ratings over C-Rating. This in part based on your [above] 'Industry-Wide Inflation of C Ratings' and 'Practical Approach to C Ratings.'
Is consideration of a battery wattage rating of more use than its advertised and often inflated a C-Rating when selecting a LiPo? Or should I stick with C-Ratings and just accept they are inflated? -AC
@ahr43 sorry, ain't been around much lately. School is taking up a lot of my free time these days.
Wattage is simply the product of voltage times amperage. The main thing that makes a lipo good, especially from a racers point of view, is how long it can sustain higher voltage while under load. What determines this is the true amperage rating of the pack. We find that by multiplying the amperage hours of the pack by the true C rating, and therein lies the problem.
The reason I started doing the battery testing is because there is no such thing as an accurate C rating on a pack so unless someone is testing lipos there's no real way to compare one lipo against another one. I mean sure you can drop $150 on an ESR meter in order to find the true C rating of a lipo but it still requires you to buy the lipo.
The only thing that does seem to be somewhat accurate most of the time is the amp hour ratings so you can go by that somewhat (higher the better) but you can have a 5000mAh lipo with a true c rating of 30 that will out perform a 6200mAh lipo that has a true C rating of 14. That being said more mAh never hurts, other than the battery will likely weigh a little more, which is also a concern for racers.
So to answer your question succinctly, if your just buying lipos based on what's printed on the label, its a crap shoot as to what you'll end up with. Luckily somebody out there has tested a bunch of brands so we have some real data to use for purchasing decisions.;)
Hope that helps
Oh and not every battery line from a particular brand will be good. A couple of examples are CNHL and Liperior.
Every CHNL battery I've tested so far is crap with the exception of their G+ line which is very good. Likewise liperior and liperior pro are some of the best lipos out there but their endurance line is garbage. (With the exception of the endurance line no prep packs which are also good). There's literally no consistency out there even among manufacturers that produce some good lipos.
Also hard packs universally perform worse than soft packs. (I'd have to double check to say this with 100% certainty but even if it not universally true, the percentage is staggeringly in the soft packs favor)
Thanks for the replies, Wolf. My take-away is to buy the most mAh consistent with the trade-off in weight needed for the application? Consider the C-Rating, but not to use it as a determining factor for purchase?
For example, in spreadsheeting data on my LiPo packs, I find, as an example, a 2S2P x 6000 7.6v shorty coming in at 45.6Wh and 2S2P x 5000 7.6v shorty coming in at 38.0Wh. Both rated "130C." That's what has my wondering if C-rating is just a throw-away in determining pack suitability?
Sort of a crap shoot this LiPo battery thing. Interesting comment on the soft packs. Has me thinking to re-look them as my racing series looks to ROAR specs for guidance but does not adhere to them. Thanks for all your efforts in sorting this out for us. -AC
All 7.6v 5000mah packs are going to be 38wh just like all 7.6v 6000mah packs are going to be 45.6wh. The only thing you can use as a measure of which 7.6v 5000mah lipo is better than another is C rating, which of course is about the same as using "Eeny, meeny, miny, moe". :)
I should also clarify that there are a lot of soft packs that are the same as hard packs. What i was really trying to say is all of the lipos in the top 10-20 positions on my spreadsheet are soft packs thereby making me pretty much swear off of hard packs these days
I think I'm stuck using hard packs for club rules.
I can't figure out how batteries that can be bashed the snot out of in skateparks are still deemed unsafe for racing by ROAR.
Yay!!! Expensive crap batteries!!!! 🙄
Excellent!
