P
I'm not the biggest fan of Duratrax, but these look like some cheap fun. I have a Duratrax Evader, which for the money is an ok truck. They pretty much pulled the chassis design from the old Losi XXT's I think (which normally I would say copying Losi would be barking up the wrong tree, but they did have some pretty proven stadium trucks back in the day).
These will be a nice cheap alternative to the mini slash.
I like the fact it comes with a 2.4ghz radio.
I believe that should be an industry standard now, not a reason to mark prices up another $100.
Will likely pick one of these up in the spring.
So, How do you like it so far. Any major issues/ problems. been thinking about one and for the price it seems like a good deal.
Hmmmm, these look pretty good imo. Definatly wanna see them in action. too bad their 1/18th. Looks like everyone is getting on the 2.4 bandwagon these days.
Thats cool track with the carpet!
great action shots there, thanks for posting'em!
Those all look pretty unique! Makes me excited to get my hands on mine and see what it's all about.
Which one is yours?
I like that one with the extra "fins" and the number plates. Are they screwed on, or just shoe-goo'ed?
I might have to pick up an extra clear body to paint up myself!
So, can you say which parts I should be weary about on this platform? Or which would be advisable to upgrade?
I see. Unfortunately I cannot find the front buggy CVD's... On the other hand, I've also read a bit about people on rctech having problems with the steel CVD's and the wheel studs breaking off too easily, rendering them useless... then people go back to the plastic and drill them out for a bigger screw or something to that effect.
I'll wait and see how the composite stock shocks do.
Are you running stock yellow springs all around? What weight fluid?
I'm assuming you are running the stock VR3 motor and stock ESC?
Oh, and are you running NiMH? 6 or 7 cell? Or lipo? I've got both, but if this "ST" ESC that the guy is including with my SC is as garbage as I hear (compared to the supposedly smoother updated ESC that currently comes with the SC) then I'll switch to brushless and go 2S lipo.
I don't think there is a low-voltage cut-off on the factory ESC, is there?
~ Yeah, the steel threaded axles suck, the threaded axles snap quite easily, seen lots of guys break them.
TowerHobbies has the buggy steel CVDs that I use. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPTT4&P=7
I found an easy mod to "fix" the issue on another forum, same thing I did. (http://one18th.proboards.com/index.cgi?board=general2&action=display&thread=396&page=1)
Either way, if you're looking for DTX parts and your LHS doesn't carry them - always go to Tower's website, they keep most things in stock.
~ I changed to green springs on the front - so it has a heavier spring on the front, which is a rather typical change for any 4wd.
~ I finally settled on 80wt front/60wt rear[/B], but that's me (and it's on a smooth carpet track - so I'm sure I'll change to thinner oils when I go outdoors this summer, probably 60/40)
~ Yes, I'm running the stock VR3 motor - it's really all the motor this truck needs, it's screaming fast (I might even switch to the slower red-label motor when I go outdoors).
The stock ESC has been updated and they work fine. Though I did upgrade to a Novak XRS, because it's a 10th scale esc and has beefier wires (they're only about $40, but a good mini speedo), but it's not "really" neccessary.
~ The Detta's tend to be plenty heavy enough on their own, for a mini, so I've always run mine off LiPO (2S) if for no other reason than to save weight.
~ As I mentioned earlier, the ESC included in the SC is updated (different than what came in the earlier ST and Buggy) - but yes, the one that came in the ST is junk (they overheat and burn up quite easily).
No, there is no LVC on any of the brushed DTX speed controls (or any RTR that I know of for that matter).
If you plan on going brushless, I'd personally look into putting a Novak Mongoose system in it. A 13.5 will be "plenty" of motor for this truck.
Let me know if you have any other questions
Thanks for the tips.
ah, that other website link you posted requires you be registered to view it.
I was wondering what the deal was with those CVD's with the screw in instead of the stud. Well, looks like I'll pick up a set of those and try them out.
Also add in some green springs, that was kind of what I was thinking, since I run it stiffer up front on my 1/10 SC's, but just wanted to ask.
I think I'll try some lighter weight fluid though.
Running the Novak XRS, huh? That doesn't have lvc does it, do you run a separate lipo cut-off?
I do have a Mongoose 13.5 set-up already, but it lives in my Kyosho Mini Inferno. I have an extra Mamba 6800 set-up though, just wondering if it would run too hot in this Vendetta?
I might just run the crappy ST ESC I'm getting with 7 cells until it fries, then look into a Tekin B1r or something. I hear these VR3 motors don't last long either though, run excessively hot. How's yours holding up?
wow thanks for all the info guys. kinda makes me think twice about adding another ride to the garage. still looks like a fun little truck.
