Cutting hole in shell to fit lamp, what material can I add to protect lamp?
King Mustard
United Kingdom
The topic title was not the easiest to make clear to understand!
Basically, I have a Maverick Quantum RX Flux and I will be cutting out a roughly 28x28mm square in the black section on the front of the shell and fitting one of these lamps.
I will still want the shell water-resistant, and I also want to protect the lamp itself.
What material is usually used to fill in the gaps around the lamp (where it joins the shell) and/or what can I place in front of the lamp to restore the shell a little?
Id cut the holes small enough to mount the light using the 4screws. Lens on front of body base on backside. Find a small wire mesh like speaker grill to protect them or a lens cover film
Then seal it with above recommended sealants
Something like this
If you have nitro fuel, that on a tip or cotton ball should rub factory paint off. No cutting required.
